Fog light question
Old Oct 29, 2011 | 05:29 PM
5speedwtneed's Avatar
Fog light question
Just picked up my evo 9 today. Only thing wrong with it is that the fog lights come on no matter what and cant turn them off. Is this a module add on? Or is there just a broken fog light switch. They even stay on with high beams... Which seems like they would go off even if the switch was bad when the highs came on. Any help is appreciated. Thanks.
Old Oct 29, 2011 | 06:43 PM
barneyb's Avatar
Well, if it is a modification to the wiring, tell me how it was done. I'd like my lights to work that way.
Old Oct 29, 2011 | 06:45 PM
Haha ok. Well didn't see anything under the hood near the lights. Unless its a module near the switch. I'll investigate more tomorrow
Old Oct 29, 2011 | 08:17 PM
sujinX's Avatar
there should be a relay under the dash. i'd like mine to come on too
Old Oct 29, 2011 | 08:38 PM
turbotalawd's Avatar
Here you go:
https://www.evolutionm.net/forums/ev...l-control.html
Hopefully they didnt butcher the wiring.
Old Oct 29, 2011 | 10:03 PM
barneyb's Avatar
Thanks. Looking at the wiring diagram for the fog lights, I can see how to do this with changing only one wire. But then the lights would be on all of the time - in other words, no way of shutting them off short of disconnecting the battery. Oh, it would be sick if you could just change a setting in the ETACS. But, I see no adjustable settings for the fogs in the service manual.
And, yeah, the above mod (or something like it) could have been done to the OP's car.
To the OP: The lights go off when you turn the ignition to off and open the door. Do the fog lights also go off then?
Old Oct 30, 2011 | 04:47 AM
My original post wasn't super descriptive. When I said always on. I mean on with parking lights, low beams, and high beams. But when all is off they are off.
Old Oct 30, 2011 | 03:04 PM
barneyb's Avatar
Well, mind you I don't really know for sure. Normal operation is that when you hit the fog light switch this sends a signal to the ETACS computer which sends a message to the front computer to close the relay for the fogs (if the headlights are on). The ETACS has the job of keeping track of things like the lights and will, for example, shut the trunk light off if you forget and leave the trunk open for 30 minutes. It also shuts off the outside lights when you turn the ignition off and open the driver's door (this feature can be disabled).
Close the door and start the car and the lights automatically come back on, all except the fogs. The ETACS resets them to off and you have to hit the switch again if you want them.
So, the switch stuck to on could maybe do this but the relay stuck to on wouldn't do this (a stuck relay would cause them to always be on). So, if the switch is okay and your car hasn't had some wiring modification I'd suggest it is the ETACS.
Old Oct 30, 2011 | 03:16 PM
Hmm good thought. I guess I'll give up and keep them lol.
Old Nov 3, 2011 | 07:01 AM
03mitsevo's Avatar
bump
Old Nov 3, 2011 | 11:32 AM
Had not looked into the real culprit of this yet. I'm on vacation for 3 more days. I'll update this in the next week though.
Marcac
Aug 30, 2011 12:59 PM
Beardly P
Jan 29, 2009 08:07 PM
stanrc
Apr 9, 2008 10:55 AM
xtnct
Mar 7, 2006 09:34 PM
kiran197
Jan 1, 2004 08:04 PM
