Atmospheric bov??????
Old Jan 5, 2012 | 02:19 PM
BOOSTDBSTRD's Avatar
Ok so i see all the time do not use an atmospheric bov because it causes havoc with your MAF, so how come it is i see so so so many people running atmospheric bov's, Is there a way to tune past this or what? I've always wondered why this is i have a Known tuner who does great work and he has told me don't use one, but he has one but, then again he runs a full stand alone so that makes sense. Is there another way? Are a lot of people doing things wrong? Just curious.
because i know it causes the car to die coming to a stop but my care already does this and i have a evo 9 diviter. Mine may be dyeing because i have big cams. what do you guys know or think about all this?
Old Jan 5, 2012 | 02:22 PM
jvlazzar's Avatar
you remove the MAF and run Speed Density instead.
https://www.evolutionm.net/forums/ec...d-density.html
http://www.google.com/#hl=en&source=...peed%20density
Old Jan 5, 2012 | 02:29 PM
GPTourer's Avatar
Originally Posted by BOOSTDBSTRD
ok so i see all the time do not use an atmospheric bov because it causes havoc with your MAF so how come it is i see so so so many people running atmospheric bov's is there a way to tune past this or what? I've always wondered why this is i have a Known tuner who does great work and he has told me don't use one, but he has one but then again he runs a full stand alone so that makes sense. but is there another way? or are a lot of people doing things wrong? just curious.
because i know it causes the car to die coming to a stop but my care already does this and i have a evo 9 diviter. but mine may be dyeing because i have big cams. what do you guys know or think about all this?
All the answers to everything you are asking are in your difficult to read post. Some capitalization would be nice. Also, just accept that there's no magic solution to make a dumped BOV work right on MAF car.
Old Jan 5, 2012 | 02:32 PM
Atrophical's Avatar
Perfectly said.
Old Jan 5, 2012 | 02:35 PM
b16a2delsol's Avatar
You can run open atmosphere just fine. I had mine running open for 6 months not a single problem. Recirculated or vented you're still going to be rich between shifts Nbd. But why do you guys want to run atmosphere so much? My dv is loud as hell recirculated
Old Jan 5, 2012 | 05:10 PM
Is that al little better? Sorry I was in a big hurry. hahahahaha
Old Jan 5, 2012 | 05:13 PM
Speed density
Originally Posted by jvlazzar
How does this speed density work? If i get this can i get a new piping kit so i can clean up my engine bay and move crap around? Also how much do they run?
Old Jan 5, 2012 | 07:42 PM
VIIIdriver's Avatar
Basically the car has to be tuned to run on speed density,if you don't tune yourself it's something you'll want a professional tuner to do,the pcm uses a map sensor instead of the maf to adjust the fueling besides other things,you'll need a 4bar or higher map sensor(the most wildly used is the Omni map 4 bar)usually sells for about $100.00,you'll also need an I.A.T. sensor to mount on your intercooler piping and harness which goes for like another $70-100.00 depending on where you buy it,the rest is tuning,it might seem like a lot to do but it's the only true way of venting your bov,the car runs a lot smoother once it's all done,i'm really happy with mine.
https://www.evolutionm.net/forums/ec...ched-roms.html
Old Jan 5, 2012 | 11:42 PM
usnevo8's Avatar
You dont actually need the IAT sensor. It is just another gauge basically.
Old Jan 6, 2012 | 12:27 AM
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
i am running a split recirculating/atmospheric BOV from agency power no problems and no rough idle at stops.... it has a threaded plug to make it full recirculating or remove it and 50/50 blow off/recirculate
link: http://www.lancershop.com/customer/p...3&bestseller=Y
Old Jan 6, 2012 | 12:38 AM
deylag's Avatar
Running Speed Density will allow the Evo to run VTA. Run a MAF and the BOV must be recirculated.
Old Jan 6, 2012 | 05:32 AM
jonzie04's Avatar
Try it out for yourself. I vented the stock bov on my car and it ran no different. Lots of others here who have tried a VTA bov on the stock MAF had had success. Some here havent. But most will preach to you not to run one, having never tried it. It's not like it's going to hurt anything. Try it out and report back. good luck.
Old Jan 6, 2012 | 05:57 AM
PatricksEvilEvo's Avatar
On stock tune it does run fine VTA, I had occasional idle fludder when coming to a stop but rarely and it never stalled. But when I had my car tuned running a higher boost, it ran like crap VTA. I have a new HKS SSQV 5 bov I'll sell if anyone wants it! Half price and I have recirc fitting. SOUNDS SICK VTA
Old Jan 6, 2012 | 06:20 AM
Ramen_Noodle's Avatar
OP, please take a moment to search the site. This topic has been covered numerous times. Closed.
boostislife
10
Mar 22, 2016 10:45 AM
bigplansnocar
Dec 9, 2011 08:49 PM
locox
Oct 5, 2008 05:46 PM
HesGotAnEvo
17
Sep 5, 2007 08:36 AM
TrskitEvo8
16
Jun 23, 2004 06:14 AM
