60k OEM timing belt kit
Old Jan 12, 2012 | 07:09 PM
thedru13's Avatar
Ok time to do my 60k. I want to go OEM or gates and yes going to replace the water pump. Not doing balance shaft elim..
so looking for the best buy.. I am going to do the work myself so just looking for good deal on parts. Anyone know the best deal out there for the full kit?
Old Jan 12, 2012 | 07:56 PM
420a-t's Avatar
STM, extremepsi, slowboyracing were pretty cheap a year ago when I did mine.
Old Jan 12, 2012 | 08:30 PM
VIIIdriver's Avatar
What do you consider a "full kit"? I bought my Gates timing belt and balancer belt from Ebay for $127.00 shipped,and bought the seals from the dealer,also bought a Gates water pump from Napa for $57.00,i've personally installed this WP on many of my customers cars with no longevity issues,watch out for "full kits" that include extra stuff you may not really need,like tensioners and pulleys,i worked at a Mitsubishi dealer for quite a while and we never replaced timing belt tensioners or pulleys with the timing belt packages,as far as O.E.M. or Gates you can't go wrong with either one,hope info is useful.
Old Jan 12, 2012 | 09:01 PM
turbotalawd's Avatar
This is bad advice. The main reasons why timing belts fail on 4g63's is because of either bad tensioners or pullies failing. Why skimp out on such a important part of your engine and risk catastrophic engine failure?
A full kit should include both belts (timing and balance shaft belts), all pullies, water pump, and tensioner. Some even come with the acc. belt.
Old Jan 12, 2012 | 10:42 PM
EmeryatSTM's Avatar
Do yourself a favor and get a full kit. IF you need help deciding on what you need, just give us a call. 585-226-8226
Thanks
-Em
Old Jan 12, 2012 | 11:29 PM
Redline-Z's Avatar
Veteran: Air Force
Thanks
-Em
I agree, replace everything! Please send me a quote for a full OEM kit with water pump for an Evo 9,
thanks Emery!
Old Jan 13, 2012 | 06:49 AM
Ramen_Noodle's Avatar
So even though this is recommended by Mitsubishi you didn't do it?
Old Jan 13, 2012 | 06:53 AM
grillpt's Avatar
I bought the full timing kit from Mitsubishiparts.net, thats what I suggest.
Old Jan 13, 2012 | 06:55 AM
EmeryatSTM's Avatar
thanks Emery!
Our kits can be found here.
http://www.streettunedmotorsports.co...g_belt_kit.htm
Old Jan 13, 2012 | 07:11 AM
gsrboi80's Avatar
You dont replace tensioners. Damn that is terrible advice
Please do yourself a favor and replace all pictured above
Old Jan 13, 2012 | 08:39 AM
reboundicon's Avatar
I wouldn't mess around with something like this, buy OEM parts only as this is probably the most important service you will have to perform on your car for a while. I would go to the dealer and buy a kit there if you can't find any deals from vendors.
Remember the timing belt/tensioner can cause a lot of issues if not installed correctly! A costly mistake that can be avoided with the proper parts and install (read the FAQ on the install on evoM).
Old Jan 13, 2012 | 09:24 AM
kyoo's Avatar
bought mine from mitsubishparts, works great, im sure other vendors offer similar @ similar prices. gates belts, not oem, everything works perfectly
Old Jan 13, 2012 | 09:29 AM
Anarchy99's Avatar
Always replace autotensioner, main tensioner and tensioner bolt... Anyone that tells you its not needed, run far away from.
Old Jan 13, 2012 | 10:17 AM
EmeryatSTM's Avatar
Our kit is 100% OEM too. As many said, Its probably the most important service you will do to your car so please do it right.
-Em
Old Jan 13, 2012 | 10:21 AM
555R's Avatar
how tough is this service to do at home
just wondering
