Ams vs Brad Penn oil
Old Jan 24, 2012 | 04:09 PM
  #121
apagan01's Avatar
Originally Posted by cursedsm
Hmm nothing on there web page about it being bad for e85. In fact they sell it with other race fuels. And no fact of them going out or even suggesting going out of business.
This will answer any questions regarding runing ethanol with brad penn
https://www.evolutionm.net/forums/ev...brad-penn.html
Old Jan 24, 2012 | 04:11 PM
  #122
apagan01's Avatar
For whohever is intersted in analysis results from different oils:
https://www.evolutionm.net/forums/ev...g-testing.html
Old Jan 24, 2012 | 04:16 PM
  #123
apagan01's Avatar
Dyno oils that are loaded with hydrocarbons this is what happens to them:
Hydrocarboons are something petrolium oils contain naturally and PROVED over and over not to be good for engine internals.
MUST SEE:
https://www.evolutionm.net/forums/ev...d-jello-4.html
Old Jan 24, 2012 | 04:38 PM
  #124
CurseDSM's Avatar
Thanks for bringing that up I forgot about that. I didn't buy it when I commented in that thread and I don't buy it now. The gumming they talked about has been covered a few times and it was due to the e85 itself not the oil.
Old Jan 24, 2012 | 04:49 PM
  #125
CurseDSM's Avatar
MUST SEE:
It is interesting to see that but I don't run 20/50 oil so being its thick oil to start I am not really impressed by the video at all. Thick oil, been run for x amount of miles, sitting in a container well no **** its gonna look like that. If he were to open his oil pan and that came out of the car after it was driven I would be more hesitant. I have Brad Penn oil sitting my grage from a year ago with 2000 miles past my 3k service I usually do in 10/30 and it doesn't look like that one bit.
Old Jan 24, 2012 | 05:29 PM
  #126
xRoguex's Avatar
Originally Posted by gsrboi80
Um no as stated previous "Your not running monster cam flat tappet motor from 1960"
Originally Posted by evoxsi
dont bother Rogue, i bet this guy still thinks carbs > efi aswell.
..... 4ws tuned.... Like any one is supposed to take what he says seriously...
Old Jan 24, 2012 | 05:55 PM
  #127
gsrboi80's Avatar
Funny cars still has the OEM block making good power for most it's life. Sorry you got butt hurt tough guy that sucks.
Thing that sucks with the oil deal though is that in reality you just follow what you hear like a sheep and post up BS like a puppet. No tough guy your roller lifter 4G63 engine does not require those levels of ZDDP hell I think you can probably find that out in a 5 min search.
Thug on buddy
Old Jan 24, 2012 | 06:02 PM
  #128
TurboTravis's Avatar
Originally Posted by Ryan.Kauz
My last UOA was a few oil changes ago at 12K miles on the same fill/filter without the need of topping off. Was still within spec. (10w40 high zinc Amsoil and their absolute efficiency oil filter)
I'm currently at 14K miles on the current fill/filter and will try pushing it to 16 or 20K to see where the drop-off occurs.
Note: This is on a DD evo with ~350whp. Come summer time I wouldnt try to run that distance as the car is run harder.
Point proven, and good to see you getting your money's worth out of the oil.
With that said, I think that most stock-ish Evo's that are well tuned could go ~5-6K on a good dino oil like Rotella.
Old Jan 24, 2012 | 06:04 PM
  #129
FWIW, Cen-Pe-Co oil has more zinc/phos than anything that AMSOIL makes.
http://www.cen-pe-co.com/
Old Jan 24, 2012 | 06:14 PM
  #130
TommiM's Avatar
There always seems to be a debate whenever which oil to use is discussed on forums. From reading Im sure we have all learned that our 4g63 needs an oil with high levels of zinc and phos. Everyone on here has been arguing about what is the best oil, but no one is saying much about the other chemicals in oil. Besides zddp what should we be focusing on as far as contents in our oil? Some manufacturers, for example, like to use a large amount of Calcium as an additive. Others youll see larger amounts of Boron or even Titanium. My question to all you evo gurus is where do all these detergents and additives factor in when considering which oil to use on a 4g63?
Do we want or really need an oil with large amounts of Calcium in our turbo engines which produce a lot of heat? Im just throwing out one of the other additives found in oil as an example because I havent heard anyone else mentioning how the other chemicals in the oil of one brand stand up next to another.
Old Jan 24, 2012 | 06:47 PM
  #131
rodent's Avatar
Trust me, the 20w/50 wasn't near that thick when it went in. I had less than 500 miles on the oil. I started the car once a month and would take it for a spin for an hour on nice days. It was in the container for a week before I made the video. The container was new from the Mobil1 15w-50 I replaced the BP with. I'll NEVER run Brad Penn again.
Brad Penn contacted me after I sent an online contact submission explaining the issue with the gelling. Both Ken Tyger and Chuck Armstrong called me to discuss over the phone. These guys are both the oil gurus for Brad Penn and I was pretty impressed they were both taking time out of their day to contact me. They basically told me that due to the time the car sat over the winter, fluctuating temps in the garage, and E85 fuel, they could see the oil doing this. They both suggested I should be running synthetic oil such as Mobil1 15w50 and stated Brad Penn 20w50 was not intended to be used with E85 fuel.
I emailed Ken after we talked asking for the API ratings I should be using with E85 and he sent me this email-
The Brad Penn PG 1 20W-50 was formulated on the API SJ platform…although it is not a licensed SJ due to the enhanced AW package.
Modern oils meeting API SM or SN are designed to be run in conjunction with E85 fuel. However, 20W-50 is not a recognized ILSAC category oil (GF-4, GF-5). If it is your intention to run a 20W-50 viscosity, I would utilize a product such as Mobil 1 full synthetic meeting SJ and the desired viscosity.
Hope this helps,
Ken Tyger
Technical Services
American Refining Group, inc.
On another note, nobody mentioned mentioned different Mobil1 weights have different zinc / phos content.
http://www.mobil.com/USA-English/Mot...duct_Guide.pdf
Also Brad Penn is known to be lower to be lower in zinc / phos with Blackstone testing.
http://www.penngrade1.com/Zinc.aspx
Penn Grade 1
20W-50 #7119
zinc 1,214 ppm
phos 944 ppm
http://www.bobistheoilguy.com/forums...Number=1452709
Old Jan 24, 2012 | 06:57 PM
  #132
CurseDSM's Avatar
Originally Posted by rodent
Trust me, the 20w/50 wasn't near that thick when it went in. I had less than 500 miles on the oil. I started the car once a month and would take it for a spin for an hour on nice days. It was in the container for a week before I made the video. The container was new from the BETTER Mobil1 15w-50 I replaced the BP with. I'll NEVER run Brad Penn again.
I would put Mobil1 15w-50 against Amsoil anyday.
Penn Grade 1
20W-50 #7119
zinc 1,214 ppm
phos 944 ppm
Thanks for that info. Like I said I have 5k oil in a cat litter jug in my garage and its no where near that thick and I ran e85 with it.
Old Jan 25, 2012 | 03:54 AM
  #133
Spec-Ops1's Avatar
Originally Posted by yellowevo82
Buschur and stm both run brad penn with e85 .. Find a person who builds a better motor then David Buschur and have them tell him he is wrong for running brad penn in all of his cars. Brad Penn is fine for e85 and a good choice. So is AMS OIL. Your comparing apples to apples.. Both are recomended its all by prefernce .. Can we end the pissing match of who's package is bigger?
I run a Buschur motor as well... and I gave the brad penn a shot, it was great oil... I daily drive my car and when the Z-Rod came out that oil fits the bill for what my car was built for... High ZDDP package and anti-corrosion packages and detergents that are great for daily driven cars...
The only complaint I had about brad penn was that locally it took a $2/QT price jump...
Old Jan 25, 2012 | 04:56 AM
  #134
SamsonEvoX's Avatar
Originally Posted by TurboTravis
No need for a synthetic oil, unless you're running the oil very hot and/or shooting for extended drain intervals.
Actually, this is incorrect. Synthetic oil has many advantages over conventional oil. One of them is the ability for the oil to quickly flow in colder temperatures. This is critical in the winter obviously to minimize galling or excessive wear due to a lack of an oil film. Another benefit is on cold start ups. Aftermarket cams like the IPS K2 as well as turbo bearings need instant lubrication to prevent lobe or bearing damage due to direct metal on metal contact.
High zinc/phosphorus synthetic oils are crucial for the life of any high performance engine whether N/A or F/I. Cam lobes and bearings, turbo bearings and rings all benefit from the enhanced lubricity. I cannot imagine running a 4G63 or 4B11T on conventional oil. We are not driving Ford Model T's for goodness sake.
Old Jan 25, 2012 | 10:29 AM
  #135
SmurfZilla's Avatar
Old skool vs. new skool
Some people will never be convinced that synthetic is worth the money you spend (esp. if you change your oil every 3k which is another hold over from the "ol skool" days) and there are some that believe conventional oil is just as good as modern day synthetic.
Why are we arguing. You will never be able to convince the entrenched on either side they are wrong.
