any ideas to strengthen the driveability?
Old Feb 4, 2012 | 08:08 AM
EvoJoeIX's Avatar
You want a smooth car, but yet want to replace all them soft rubber bushings with hard poly/metal inserts..... That seems very logical
Old Feb 4, 2012 | 08:10 AM
RelentlessEVO's Avatar
He wants to strengthen his drivetrain, not his "driveability." He's afraid with all the power he's making he's going to destroy it. At least, that's what I've gathered.
Old Feb 4, 2012 | 08:30 AM
EvoJoeIX's Avatar
He barely makes any power, why even worry about the drivetrain breaking?
Old Feb 4, 2012 | 09:46 AM
Exactly. He should have searched to find the answer to his question, which has been answered many times before.
Old Feb 4, 2012 | 09:56 AM
FJF's Avatar
FJF
Agreed.
Old Feb 4, 2012 | 08:35 PM
awdordie's Avatar
Originally Posted by thepoint4life23
I would say all the stuff you have listed will help with making feel better also. Look in to a Moustacehe Bar with diff supports that will help as well as and if you want to get crazy you could get Driveshaft bushings
not sure where you got the mustache delete bar idea fromm but even buschur himself said for a daily driven car on the street this was not a good idea. it does eliminate the clunking of the rear diff but road noise is horrible and much more noticeable. thats not improving driveabilty to me just irritability while driving.
op if you are looking to improve driveabilty do not go with stiffer bushings if anything i would suggest replacing them with new oem bushings. stiffer bushings will do just that make things stiffer and you will feel a noticeable difference. with cams and poly mounts in my car at idle it seems like every bolt is vibrating loose because all of the vibrations and bumps are transferred better into the body and therefore you feel it more.
Old Feb 6, 2012 | 10:10 AM
thepoint4life23's Avatar
From what i have read he has said you can dd your car with his mounts and mustachs bar
Old Feb 6, 2012 | 10:20 AM
Raptord's Avatar
If I'm not mistaken the OP actually mean he wants to improve the enjoyment of the car, not "driveability" nor "drivetrain". Which is why he had identified the shifter bushings, for better shifter feel, etc.
OP, correct me if I'm wrong.
Old Feb 6, 2012 | 10:29 AM
tony_b's Avatar
Replacing my base and underhood shifter bushings with metal versions was one of the best mods I did for driveability. The car shifts SOOOO smooth!
Old Feb 7, 2012 | 06:53 AM
Inflame's Avatar
I just did the blox front motor mount on my VIII and I also did it on my last VIII. It's usually the first mod I do.
Old Feb 7, 2012 | 07:07 AM
FJF's Avatar
FJF
...To be honest, I've only had the evo for 7 months and it's starting to get annoying. I've never owned a car with so many squeaks and rattles....
Ya think a different approach might be in order?
Old Feb 7, 2012 | 07:11 AM
Raptord's Avatar
FJF : EvoM's resident detective
Old Feb 13, 2012 | 07:23 AM
Riddle's Avatar
Originally Posted by Chef-j
He still wants fun
eazysnatch
Automotosports - Illinois
Mar 18, 2016 10:29 AM
yeayeaatou
Jun 5, 2015 12:06 PM
etown09
Sep 13, 2012 07:23 PM
Kracka
51
Apr 7, 2012 03:29 PM
SeanM505
Oct 30, 2011 01:13 AM
