HELLLLLPPPP!!!!! what do i do?
Old Feb 11, 2012 | 11:32 AM
  #46
blowngasket's Avatar
This is the method i use, you can try and drill it and sit there and play with it with a chisel or do it in 5 minutes like this let all the air out of the tire, pull the air stem and torch it off. BUT BE WARNED GET ALL THE AIR OUT OF THE TIRE AND PULL THE AIR STEM JUST IN CASE. thats what i would do i dont see any way of beating any type of socket on that thing, and dont forget i mean its on there tight enough to break a lug, so you could imagine how hard press you would be to try and beat a socket on it to hold it or to even try an chisel it off plus you have no room with the side walls of the rim to get leverage to chisel it. If your good with a torch you might be able to save the bolt and not damage the rim, just use caution if your going to torch it.
Old Feb 11, 2012 | 11:36 AM
  #47
CurseDSM's Avatar
Originally Posted by AJCaron12
Drill drill drill. That's how I get locking lug nuts off when customers can't find their wheel lock key. You don't even have far to go.
Originally Posted by kanovic
Try drilling it out. Get a tampered drill bit and a lot of time and might be able to drill it out and just replace a stud.
You guys are forgetting that this isn't like a regular bolt. Drilling will not make this come out. Your gonna have to get the spindel off as someone suggested, or air hammer it out or wack it out like I suggested way earlier. Once you get the stud to pop free, you will be able to cut the back of the stud off. I guess one thing all of us haven't considered even myself is, that the bolt is snug on there. Air hammering the sides of the lugnut I guess could see that working being your gonna have to replce the stud anyways being you killed the threads on it.
Old Feb 11, 2012 | 12:49 PM
  #48
SFL Autosports's Avatar
your gonna destroy the rim with an air chisel the opening is to small to get a good angle. take of the hub
Old Feb 11, 2012 | 12:52 PM
  #49
TheBoz's Avatar
Just drill the stud, then pop the bad stud out and replace. Been there done that.
Old Feb 11, 2012 | 01:34 PM
  #50
jdr7919's Avatar
I had the sameing happen to my gsx I took it to a shop and they got it off with a torch. The rim was fine. Took them about about 30 sec.
Old Feb 11, 2012 | 01:39 PM
  #51
tim85851's Avatar
drill.
Old Feb 11, 2012 | 02:02 PM
  #52
Pal215's Avatar
Originally Posted by 4whlbst
yeah i would just lay into it with a drill bit and hollow it out. There is only the taper left on the lug like u said so u won't have to drill much. A new stud is like 5 bucks and u can change it at the house when ur done. Honestly it shouldn't be that big of a deal at this point, just a little patience and time.
+1
Old Feb 11, 2012 | 07:51 PM
  #53
EVO10190's Avatar
yea thanks for all the advice i think im gonna stay clear of a torch any heat near an aluminum rim imo is bad... so i guess im gonna try drilling it out or an air hammer... ill maybe just say **** it n bring it to a shop idk...
Old Feb 11, 2012 | 07:53 PM
  #54
EVO10190's Avatar
just want these rims off, they're just my winter tires... not a big problem now just wanna get my summer tires/wheels on, and dont wanna get stranded with a flat and not be able to get off the tire
Old Feb 11, 2012 | 08:05 PM
  #55
EVO10190's Avatar
tryin to get theses off:
and get these back on:
For Sale - Wheels / Tires
May 24, 2016 09:15 AM
Red_06_EvoRS
Outlander Sport
Dec 23, 2015 07:10 AM
EVO10190
Northeast Region
Aug 24, 2015 07:58 PM
EVO10190
Aug 12, 2015 03:49 PM
EVO10190
Aug 11, 2015 06:06 PM
