ac compressor problem
Old Mar 7, 2012 | 03:24 PM
rastamike's Avatar
help, the compressor pressure relief valve in my 2006 gsr keeps poping out . i replaced the valve in the compressor,dryer,expansion valve and the dual pressure valve in the high side line.problem started after my battery died and i jumped started the car. any suggestions would be welcomed. thanks Rasta mike.
Old Mar 7, 2012 | 07:33 PM
VIIIdriver's Avatar
The valve pops off due to high pressure,how are your pressures? When does the valve pops? at idle or when driving? how long does it take to pop? It's kind of hard to diagnose without being in front of the car but i can give it a shot,i've seen bad fan modules allowing temperatures to rise enough to pop valves and clogged lines rising pressures sometimes
Old Mar 8, 2012 | 03:30 PM
rastamike's Avatar
thanks for trying, i replaced the compressor clutch relay and i think that was the problem.i am low on freon due to release from valve.the problem stated when the battery died overnight and i jumped strarted the car with the ac switch on. i am assuming that the surge from the other battery fryed the compressor relay.the compressor was not cycling due to the relay stuck in the on position.i think this caused the excessive pressure build up. i will know for sure after i add freon and some oil.Rasta mike
Old Mar 8, 2012 | 03:38 PM
rastamike's Avatar
pressures were good when i replaced those parts,and it would pop when idling.Rasta mike
Old Mar 8, 2012 | 05:25 PM
EVO8STI's Avatar
ac fan is not kicking in or you have a plug somewhere! trust me i work ac all day long. considering the parts you replaced id say you have a bad receiver drier or bad fan!!!!
Old Mar 8, 2012 | 05:26 PM
EVO8STI's Avatar
this sounds good also lol. sorry i responded before i read thru all post.lmao
Old Mar 8, 2012 | 08:05 PM
VIIIdriver's Avatar
That will also do it,keep us updated
Old Mar 18, 2012 | 09:03 PM
rastamike's Avatar
problem solved. it was the compressor clutch relay.$28.00 at the dealer.Rasta mike
neonglh
Sep 3, 2021 10:29 PM
Lumpy
Lancer Troubleshooting
Sep 2, 2010 08:34 AM
locox
Oct 5, 2008 05:46 PM
KazzEvo8
13
Jul 5, 2006 04:40 PM
gadsmevo
13
Jan 27, 2005 11:11 AM
