It will take a while to start. Help!
Old Apr 25, 2012 | 07:08 PM
loco21's Avatar
So my '03 evo 8 will take a few minutes to start it sound like is the starter but I replace it with a new one but the problem continue. You turn the ignition and sound like tac tac tac until it acctually crank. I cahnge the battery terminal also battery test out good and when you crank it the lights on the dash will stay on at all times. Has anybody here had a similar issue like this before that can point me on the right direction. Any replies will be appreciated.
Thanks
Old Apr 25, 2012 | 07:16 PM
STLEVOIX's Avatar
Check all grounds, make sure they are clean and tight. Also you can check the resistance in the wires...How many miles on odo?
Old Apr 25, 2012 | 07:29 PM
loco21's Avatar
114460. It is pretty much stock. TBE, Cams, BOV.
Old Apr 25, 2012 | 07:53 PM
AWDBus's Avatar
x2
Where and what battery setup do you have? Is it stock location (big or mini battery) or remote mounted?
Old Apr 25, 2012 | 07:55 PM
loco21's Avatar
Stock. A big one.
Old Apr 26, 2012 | 07:59 AM
VIIIdriver's Avatar
Bring it by dude we'll figure it out,that's the same reason it was hard to get the tune out the first time around,call me !
Old Apr 30, 2012 | 08:36 PM
loco21's Avatar
After I check for bad grounds and not founding any bad one I took it to test the battery again this time it came out that it was bad. I change it and problem solve. Thanks every one for your comments.
DRKalinowski
Lancer Troubleshooting
Dec 28, 2016 09:46 AM
eXtreme-Speed
Aug 7, 2016 06:14 AM
NeedBoost!
Jun 20, 2016 03:29 PM
mossontree
Oct 28, 2013 10:26 AM
