Rattling exhaust
Old May 8, 2012 | 07:52 AM
romogst's Avatar
Regardless of the problem the GReddy TI is one of the best catback on the market. Rolled tip = bad ***
Old May 8, 2012 | 07:17 PM
bt1's Avatar
bt1
I have an Injen SES on my 04 with a slight growl/vibration that happens during deceleration between 4000 and 3000rpm. Thought it was a heat shield at first, but no luck there. Does not seem to be getting worse, will cut out and install a Vibrant resonator if it gets worse.
Old May 9, 2012 | 06:41 AM
j_barcarse's Avatar
I know! I love my exhaust... Not only the thing cost me almost 2G's it never rusts lol.....
I spoke with Greddy and they will fix it if I can prove I bought it recently.
Ive had mine for quite a while now..
can someone make me a fake receipt?? hahhahaha jp
Old May 9, 2012 | 06:44 AM
j_barcarse's Avatar
Originally Posted by Freddie@Spec-Ops
I have the same issue... I had the car running on the lift, and it is not hitting anything... mine sounds like it is coming from the resonator, not the muffler. I am going to remove the resonator and see if it goes away...
did you remove the resonator yet?
how did you come to that conclusion??
wonder if its my problem too.. because ill be glad to get a nice new titanium test pipe lmao
Old May 9, 2012 | 10:45 AM
Spec-Ops1's Avatar
I came to that comclusion when I was underneath the car with it running... the rattling was more prominent around the resonator not the muffler...
Old May 9, 2012 | 10:58 AM
nirvancol's Avatar
Mine just started doing this too. I think it's hitting the heat shield near the rear O2 sensor. I already had to trim it when I installed everything. So I think I'm going to get some torque solutions hangers and maybe cut the heatshield
Old May 14, 2012 | 09:40 AM
j_barcarse's Avatar
i KNow there is one bolt loose . I fugured it was that so what I ended up doing was using some electrical wire and wrapping it around temporarily... so that it dont vibrate and the sound still came to.... ill try to figurre out more stuff
Old May 15, 2012 | 11:33 AM
blackoutVIII's Avatar
you will need spacers on the bolts that hold on the the bar that comes across the downpipe. mine used to rattle. added the spacers/washers, fixed the problem.
blknblubkrdude
Mitsubishi TC-SST Discussion
10
Apr 10, 2015 09:08 PM
SilverNine
Nov 10, 2011 01:11 AM
oceanminded050
28
Sep 6, 2010 09:56 AM
Noize
Jul 25, 2009 05:07 PM
Jinu0808
31
Feb 19, 2004 07:45 PM
