Battery in trunk
Old May 8, 2012 | 07:31 PM
Mochafrap's Avatar
Battery in trunk
Hello,
Im going to move my battery in trunk, do i need to have a some kind security/safe box for battery? Or is it safe to have without it?
Thanks
Old May 8, 2012 | 08:10 PM
FlyingCaveman's Avatar
it comes down to the type of battery. I have a sealed Optima Yellow in my trunk with no box and have never had problems from the inspectors. if it's not a sealed battery then you will need a box.
Old May 8, 2012 | 08:26 PM
gotpsi?'s Avatar
You need it to be held down no matter what kind of battery it is.
Old May 8, 2012 | 08:47 PM
Thore's Avatar
This was a good write up for it.
https://www.evolutionm.net/forums/ev...elocation.html
Old May 8, 2012 | 09:03 PM
03EVOGUY's Avatar
^ +1 also if you plan on doing drag or autocross or road racing, you need to have a battery cut off switch on the outside of the car. I.E. back of trunk or where the license plate is.
Old May 8, 2012 | 10:19 PM
Chef-j's Avatar
I have one in trunk without box. No problem so far, but you will feel alot better with box tho.
Old May 9, 2012 | 11:31 AM
Mochafrap's Avatar
Thank you guys. Will that box needs modif to fit battery? Is there any installed pic?
Old May 9, 2012 | 03:32 PM
foxbear2277's Avatar
No battery box needed lol... go for broke
As long as you use a sealed AGM battery you will have zero issues! Heres my setup. (major thanks to ezzey for the help with the custom battery mount)
This pic was taken when it was being instaled, It is unfinished in this pic, but you get the idea Shes safe and sound where the battery should have been from factory
Old May 9, 2012 | 07:34 PM
Mochafrap's Avatar
Very nice. But will you feel safe to put stuff in your trunk? My car is DD, sometimes i have many things to put in the car.
Old May 9, 2012 | 07:57 PM
akeric's Avatar
I would box it, my track requires a box regardless or dry-cell or wet-cell. At the very least you won't have to worry about something bumping into it.
Old May 9, 2012 | 11:08 PM
Thore's Avatar
Just hit up your local part store and get the marine box enclosure. For a DD I wouldn't feel comfortable with having exposed terminals. I think the box was less than $20 last time I checked.
Also, make sure you use bigger gauge battery cable.
Old May 10, 2012 | 06:57 AM
hennessey01's Avatar
i just had mine moved to the trunk. The battery box makes it look a little clean but need to do some more cleaning out of my trunk lol.
Old May 10, 2012 | 07:06 AM
GTijoejoe's Avatar
The purpose of the battery box is to protect the driver if the thing explodes... is there a battery box in your engine bay? no, because there is a fire wall. Does there need to be a box in your trunk... basically, no.... if it is possible to battery acid to come in contact with the driver in any way, that is where a box should be considered.
Hope that is the simple logical answer you were looking for.
Old May 10, 2012 | 10:03 AM
I have a sheild blocking the front of the battery connections. I have no worries putting anything in my trunk, went camping last year and fully loaded my trunk without an issue Plus if you really have things that can fly around in your trunk...well id advise against that and reccommend getting a cargo net, or trunk organizer to ensure things dont fly around. All in all its preference
Good luck with your relocation
Logical yes.. but... remember a AGM battery is filled with gel elctrolyte, even if the battery did explode (which chances are literally next to none), it is not a liquid. (on regards to non AGM batteries, a vented battery box is a must to ensure fumes and acid over spill is not allowed in the passenger compartment) I can see the box helping the battery not getting damaged from items loosely left in trunk under spirited driving. Only other reason id think of it is if it was required at a track, other than that, its not needed. But again the option is totally up to you! If you really see an issue, box it up and call it a day
Old May 10, 2012 | 11:32 AM
Mochafrap's Avatar
I see. Thank you guys!!!
Insanity Evo
Dec 17, 2014 08:17 AM
fasfour
Oct 5, 2010 12:17 PM
X91EVO
34
Jan 23, 2009 05:16 AM
Nomad4g63
Jun 22, 2008 02:13 AM
EvilBlueEvo8
Oct 19, 2006 06:49 PM
