Oil Smell @ 21psi
Old May 10, 2012 | 07:59 AM
Initial_r90's Avatar
Oil Smell @ 21psi
Hello all last night dropping my friend off did some spirited driving and as soon as I stopped I got a oil smell coming from the car.
Only thing I have done differently last night from since I got the car was I upped the boost to 20psi from 21psi
I have the following mods done
39k miles on the motor and oem turbo
HKS 264 cams
Map open o2 dump(sounds great at wot)
HKS intake
10.5 hotside
Perrin Catback
Halman MBC
255 pump
Hawk pads
Greddy RS bov
Compression is
175
170
180
185
I'm gonna assume this is a crankcase vent issue or tune issue I could not see if the car was smoking as it was raining.
Any insight would be great
Thanks
Old May 10, 2012 | 08:24 AM
boostedmkiii's Avatar
I would first check for simple things, such as crankcase vents/piping/hoses (however you have it set up).
Any noticeable leaks?
Old May 10, 2012 | 08:33 AM
BluEVOIX's Avatar
Are your PCV's venting to atmosphere or oem routes? Other than double checking the PCV's are not clogged etc..
Did you check the turbo for any play? Also, any oil in intake that may have leaked from the turbo?
Old May 10, 2012 | 08:46 AM
I have not checked any yet after work I may take off the intake and check it out for shaft play, oil, ect.
The PCV looks like a oem setup
Nothing is leaking under the car.
Old Jul 31, 2012 | 06:46 AM
So this is still a problem but now everytime I boost all I smell is oil @ 24psi. I'm gonna take out my PVC today after work and check it . If I buy a catch can it must be a duel inlet with a breather correct? It would be hooked up to both ends to the valve cover and plug the intake ?
Old Jul 31, 2012 | 03:26 PM
dillonb's Avatar
are you sure your not smelling the open dump? you should probably stop just upping boost
Old Jul 31, 2012 | 04:17 PM
mcm308's Avatar
As far as the catch can, Yea, I plan on the same type setup
Old Aug 1, 2012 | 05:47 AM
the hose kept poping off the intake no problems now. The boost got turned up since I got tuned
Egal44ARock
Jun 24, 2015 09:30 AM
joey0480
Nov 21, 2013 06:32 AM
racing_girl
Feb 9, 2013 05:57 AM
BOOSTINAT30PSI
54
Jun 28, 2012 10:27 AM
MikeyT
Aug 29, 2010 07:23 PM
