First time at a drag strip :(
Old May 12, 2012 | 09:04 AM
Ian0611's Avatar
Originally Posted by SlavaGC8
I'm glad I got window tint. I was ashamed to roll them down lol.
Coulda been a lot worse man. My first time at the track I ran 15.0 @ 95mph
Old May 12, 2012 | 09:12 AM
SlavaGC8's Avatar
First run was 16.4
Most runs we're in low 14's
Oh the feeling of driving a 12 second car a full second slower.
Old May 12, 2012 | 09:17 AM
PearceEVOix's Avatar
It's your clutch and you just need some more practice. I'm running an ACT in mine and I have the lockout issues, if I try to shift above 7k. I ran a 12.5 at 110 I think. Could also have a lot to do with how well you launch your car.
Old May 12, 2012 | 09:18 AM
maevo8's Avatar
hahaha my first run was also a 16 , i had no problem wih it cuz i was just learning it ,, i have the act street clutch and i have never had any lock out issues..
Old May 12, 2012 | 09:47 AM
SlavaGC8's Avatar
Also how can I improve with boost in between shifts? Car falls on its face in between shifts.
Wish I could shift this as quick as I do rsti.
Old May 12, 2012 | 09:48 AM
SlavaGC8's Avatar
What mods?
Old May 12, 2012 | 09:51 AM
meltdown's Avatar
Originally Posted by heel2toe
From what I have read, some ACT clutches have high RPM lockout issues. That is probably what you are experiencing. Did you get a single clean run in? You should be trapping way higher than 102 btw. Shift point varies from car to car but generally you want to shift when the power starts to fall off. On the stock turbo this is around 7200-7500 depending on your setup.
That's when I shift on my ACT clutch and have NOOOOOOOOOOO issues.
Old May 12, 2012 | 10:17 AM
Ian0611's Avatar
First run was 16.4
I know the feeling
Are you running an MBC or electronic boost controller? Also, what BOV are you running? If it's falling off that bad you probably have some boost leaks or your BOV is leaking. Depending your boost control set-up, that could also be part of the problem.
Old May 12, 2012 | 10:19 AM
SlavaGC8's Avatar
It's a hallman mbc and bov is oem metal one.
I'll do a boost leak test sometime. Need to research on DIY for it.
Old May 12, 2012 | 10:20 AM
SlavaGC8's Avatar
I also have a plastic dv, could swap it out to see if anything changes.
Old May 12, 2012 | 10:25 AM
Ian0611's Avatar
I know a lot of people run the metal OEM BOVs but I personally haven't had good luck with them. I noticed a huge difference when I switched to the Synapse. Boost definitely feels like it comes on faster between shifts. Also, the stock BOVs, whether metal or plastic, tend to leak past 24-25 psi.
The Hallman MBC is good and should be helping with spoolup so you probably have other issues.
Old May 12, 2012 | 10:38 AM
finalflash_17's Avatar
My first. Run was 13.2 with injen kit and tbe....not bad considering I had exhaust manifold leak and that week after the track I changed the underhood bushings and the oem ones were torn lol I was wonderning why It was so hard to shift
Old May 12, 2012 | 10:59 AM
SlavaGC8's Avatar
What under hood bushings you get? It help with shifting?
I know that oem o2 housing and Licp are very restrictive. So those are on my to do list.
Would I know if bov leaking during boost leak test? Or do I just need to try other brand?
Old May 12, 2012 | 11:14 AM
What mods?
AEM short ram intake, JGT500 tbe, hks 264 cams, wally 255, grimmspeed 3 port ebcs, act street w/ lightweight flywheel, CBRD tuned to 26psi, 3.5in fmic. That 12.5 was with a horrible launch and very slow 60ft. I guarantee that every time you go to the track your times will get better and better.
Old May 12, 2012 | 11:21 AM
Ian0611's Avatar
You might be able to hear or feel leak during the test. The main problem that I had with the stock BOVs is that it felt like theyweren't closing fast enough when I was driving and that's something you can't check during a boost leak test. But that was another difference I noticed after changing to the Synapse. My AFRs used to go really rich between shifts and that problem is much better now.
