First time at a drag strip :(
Old May 21, 2012 | 08:51 AM
  #76
SlavaGC8's Avatar
Well you have a 9 so you can get away with just bolt-ons.
Think we could do a log on mine? I dont have tactrix cable
Old May 21, 2012 | 08:55 AM
  #77
ToddRhodes's Avatar
I just need to get familiar with it but yea, I wouldn't mind doing that. I've tuned with Link for years on DSMs so other than getting used to a new interface it should be pretty simple. I won't be at the track this Friday as I'll be on vacation with some friends but hopefully the next weekend I'll have my DSM out for it's last drag strip visit and I'll have my laptop with me. Just need the cable at that point. It's supposedly on its way.
Old May 23, 2012 | 06:00 AM
  #78
High_PSI's Avatar
Originally Posted by SlavaGC8
Highest trap speed was 102. Whats a good shifting rpm? Seemed like it was a bit easier to shift into gear at 6500.
That is bad. what is your boost? Some 100% Stock Evos trap at that, some higher.
You should be at at least 114MPH, my 2003 with less mods ran a 12.3 @ 112MPH with a 1.66 60 foot on my 9.8 Hotside Evo VIII Turbo.
You are making about 230WHP with those mods. a 300WHP Evo would be at 108-110MPH. 360-370 WHP would net you 116+ MPH.
Look for an Evo IX turbo, make sure you purchase a HKS Intake, all others make less power. Sounds like you have a MASSIVE boost leak, I am willing to bet your Throttle Body seals are leaking like a b1tch. Mine were and when they were replaced I got 5 PSI back.
Good luck
Old May 23, 2012 | 06:22 AM
  #79
tony_b's Avatar
Another question I haven't seen asked... Since you said you're shifting at ~6500, are you shifting to 5th at the end of the track? You should be leaving it in 4th and staying in it at the end of the run. THAT could be what's killing you.
Old May 23, 2012 | 07:11 AM
  #80
notjdm05MR's Avatar
Check around your EGR valve and see if any of those vacuum lines have came off behind the manifold. Also if you have stock shaft seals they are more than likely leaking very badly. The ACT shouldn't be the problem I make over 400/400 and it doesnt slip and I dont get lock out.
Old May 23, 2012 | 11:54 AM
  #81
cmspaz's Avatar
Totally.
I'll be revving to 8k this year just to avoid that shift or the rev limiter across the line.
Stock cams, bottom end, and VIII turbo, I was shifting 1-2 and 2-3 at 6k, 3-4 at 6.5k, and then revving out 4th. I was in 4th before the 1/8th and trapped 114 in 12.007s. I'll be upping the 2-3 and 3-4 shifts to 6.5-7k this year with the new mods, should still be in 4th before the 1/8th.
Old May 23, 2012 | 07:27 PM
  #82
SlavaGC8's Avatar
The second time I went I shifted around 7k and stayed in 4th till the end.
I'm going to buy a boost leak tester instead of making one even though I got all the parts. It's cheaper and looks like its a good quality.
http://www.turboboostleaktesters.com...archpath=25078
Think Prosport boost gauge shows 25-26 psi but I don't trust it at all. It's been acting up.
I could have gotten a better time but didn't see a need in abusing the car for no reason, because there simply isn't enough power for much better results.
Old May 23, 2012 | 07:31 PM
  #83
SlavaGC8's Avatar
I'm going to add some bolt-on parts and retune the car for 93/e85 and try again.
Deffenetly replacing the shaft seals. I did see a sensor without a vacuum line. I'll take a pic of it.
I'll report back on boost leak. Also believe there is a slight pre turbo exhaust leak.
Old May 23, 2012 | 09:55 PM
  #84
High_PSI's Avatar
Those seals are a HUGE issue I can almost guarantee it. Get proper FMIC and piping it'll help a great deal. 25PSI or so and your set.
Llew
Mar 24, 2016 05:03 PM
SiriusEvo
Feb 26, 2016 07:42 AM
AngryEvo8
106
Nov 20, 2014 02:56 PM
EvoByDarwin
Apr 29, 2004 11:51 PM
MitsuRider03
Northeast Region
56
Mar 6, 2004 11:20 AM
