coilover question
Old Jun 4, 2012 | 01:08 PM
mrevo331's Avatar
coilover question
so looking at my car i notice the drivers side is higher then the passenger side. i pull out a tape measure and theres about a 1/2" difference between the 2 sides. i thought maybe i set them wrong or something came loose so i pulled the wheels off and check my coilovers.
heres what i dont understand. the 2 front and 2 rears have the same measurement! im measuring from the spot on all 4 coilovers also. i dont understand how this measurement is the same but the passenger side is still lower then the drivers
how can i make both sides even? is it okay to have the coilover measurements uneven to make the car sit even?
Old Jun 4, 2012 | 01:22 PM
Mistaken's Avatar
Ive had this issue with other cars and coilovers as well. If it was a big difference Id just adjust it accordingly. Otherwise I would just leave it as is.
Old Jun 4, 2012 | 01:23 PM
mrevo331's Avatar
1/2" is a pretty big difference. it really bugs me too
Old Jun 4, 2012 | 01:44 PM
Mistaken's Avatar
You should adjust them to either be as low or as high as the other.
Old Jun 4, 2012 | 04:50 PM
GTijoejoe's Avatar
Are you 100% sure you are on level ground?
Also, your car isn't perfectly corner balanced so there is some weight adjustment to height.
These two things combined can certainly amount to 1/2"
Old Jun 4, 2012 | 05:06 PM
mrevo331's Avatar
yes im 100% sure its on level ground
i thought the weight distribution would be what causes this. i guess ill just re adjust them on the drivers side
Old Jun 4, 2012 | 05:29 PM
chubtastic's Avatar
if they were corner balanced it would make a difference but that would mean one has a higher compression rate then an other wouldnt?
Old Jun 4, 2012 | 05:35 PM
mrevo331's Avatar
the car was never corner balanced, so i know nothing about that stuff
Old Jun 4, 2012 | 07:17 PM
GTijoejoe's Avatar
no, it means the car is balanced with balasts or one way or the other to have more even distribution FR R to L and RR R to L... the spring rates would not change from the manufacturer. Often times however your OEM vehicle may have slightly different spring rates (yes even R to L) because of corner balance differences to balance the ride height.
Old Jun 4, 2012 | 09:33 PM
Blue91lx's Avatar
Also, if your car was drag raced at all your frame could be a bit twisted. Nearly all of my Foxbodies sat an inch higher on the left than the right from the car twisting when launching.
Old Jun 5, 2012 | 12:00 PM
EvoJoeIX's Avatar
I had the same issue, do what you can to make the car sit even. Dont worry about the coil over mesurement
Old Jun 5, 2012 | 12:36 PM
blowngasket's Avatar
just sit in the drivers seat it will even out lol.
Old Jun 5, 2012 | 01:49 PM
EvoJoeIX's Avatar
i think you would have to be really fat or have super soft spring rates to even the car out a 1/2" on coilovers. haha
Galaxshiel
Nov 19, 2016 09:58 AM
MontanaKid
Sep 23, 2015 02:10 PM
Nzo
Jun 5, 2014 03:21 PM
lazyrichi3
Sep 20, 2011 08:19 PM
pgmike
Lancer How Tos / Installations
Sep 22, 2004 05:58 PM
