Need Help with Smog, plz!!!
Old Jul 5, 2012 | 01:05 AM
dreamcast731's Avatar
Hi all,
I'm from California, so I'm trying to get my car smogged, it passed all the test except the FUNCTIONAL test... So my car has a tune from GST awhile back, and the tuner disabled my rear o2 sensor to get rid of the CEL. My question is, will reflashing the ECU to stock map turn the rear o2 sensor back on? I plan to put my stock CAT back on, plug in the rear o2 sensor and flash it back to stock map, will it pass then? Please, any input would be great, my registration is due on the 28th.... Thanks guys!!!
Old Jul 5, 2012 | 01:09 AM
Throttle's Avatar
english racing has some sort of a tune that forces emissions pass. call them and ask. and you should definitely be running the stock cat.
Old Jul 5, 2012 | 09:06 AM
evodriver49's Avatar
which part of california are you from? i might be able to help you if youre in socal
Old Jul 5, 2012 | 11:23 AM
blowngasket's Avatar
Force Pass, patch thru ECU Flash, OR fix the rear O2, by adding the gap peice, i used two to gap my rear o2 correctly, till i did the force patch and then used my Rear O2 wires to help me log my Wideband thru my Ecu, thru EvoScan.
Old Jul 5, 2012 | 11:39 AM
chris the man's Avatar
does e85 help as well???
Old Jul 5, 2012 | 11:41 AM
o yes youll be able to pass with a testpipe on e85 but visually...!
Old Jul 5, 2012 | 12:27 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by dreamcast731
Hi all,
Have you tried calling GST and getting their advice?
You should be able to work around this with EcuFlash.
https://www.evolutionm.net/forums/ec...us-mrfred.html
Old Jul 5, 2012 | 12:45 PM
sujinX's Avatar
this is the functional test.. http://www.smogtips.com/functional_inspection.cfm
A. Engine Ignition Timing
B. Check Engine Light
C. Gas Cap & Filler Neck
D. Exhaust Recirculation Valve (EGR)
E. Fuel EVAP Test (LPFET)
u cant just reflash the ecu to stock for the functional test if your missing stuff. I am betting u failed because your missing something visually and that the rear o2 is not ready because its disabled. you left out some critical information as to if u have a hfc, test pipe or what as well as if you completely removed your rear o2 sensor or not. if u put back all the visual stuff and do what golgo posted, it should work.
they HAVE to tell you why your failed so u can fix it. you should have asked them. my friends stock car (an avenger) failed 2 times because the lady was too lazy to lay down and look for the o2 sensors. it has like 4 or whatever i dont know, but he finally on the 3rd time told her to lay down and point it out to her and he passed.
Old Jul 6, 2012 | 02:01 PM
I'm in Norcal..... Thanks tho!
Old Jul 6, 2012 | 02:03 PM
I have a mil.spec 100 Cell Cat with Heatshield. My rear 02 is still there, just disabled and ziptied to the side. Visual is NOT an issue, just the stupid computer FUNCTIONAL test.....
Old Jul 6, 2012 | 02:04 PM
Thanks for all the input so far guys!!! Much appreciated!
benIX
May 6, 2016 02:00 PM
p8471
Mar 28, 2016 07:24 PM
sdk1m
Aug 27, 2014 11:35 AM
Gonzo314
Jul 3, 2006 05:24 PM
Secret Chimp
West Region
22
Feb 21, 2004 06:30 PM
