Brian Crower Retainers on GSC Beehive Springs
Old Sep 28, 2012 | 08:45 PM
I-5 Evo's Avatar
Could someone please tell me if this works? Just trying to save myself $100
Old Sep 29, 2012 | 05:32 PM
I-5 Evo's Avatar
bump
Old Sep 29, 2012 | 07:16 PM
lostsoulsevo's Avatar
look at the tech specs, it tells you the diameter of the spring and retainer
Old Sep 29, 2012 | 10:00 PM
Graphic's Avatar
I would like to know too.
Old Sep 29, 2012 | 10:20 PM
evoxsi's Avatar
i dont see how since the bc springs are not beehives.
Old Sep 30, 2012 | 12:13 AM
jtanner_'s Avatar
^ this.
In for results... I've been looking at slowly piecing parts together..
Old Sep 30, 2012 | 09:56 AM
dastallion951's Avatar
Just buy the bc springs with the retainers, don't get me wrong gsc beehives work, but the spring design is different, personally I'm running bc springs retainers for past 45 k.....no issues.
Old Sep 30, 2012 | 11:35 AM
I-5 Evo's Avatar
I have been running BC Springs + Retainers for 30k on HKS 272s and want to switch to GSC S2s with their Beehive Springs. I really don't want to spend the extra $200 on another set of retainers if the BC Ti ones will fit. That does make sense that they are a different design of spring so they probably wont fit. I would like a definitive answer though.
Old Oct 4, 2012 | 12:38 PM
then i would call bc and gsc up tell them what you wanna do and find out if there interchangable. No one here including myself would know unless you look up the specs, personally I wouldnt mix n match two valvetrain companies with different parts that are designed different. Cams one company and valvetrain another, yea you should be fine. So trying to get your answer, go to the source. good luck
Old Oct 4, 2012 | 01:32 PM
Graphic's Avatar
GSC Spring dimensions:
Inner dimension - .5700
Outer dimension - .742
Now you just need the ID and OD for the BC's and you will have a definitive answer.. Does anyone have these measurements?
Old Oct 4, 2012 | 01:35 PM
Adam Brunson's Avatar
No they do not work. BC retainers are not made for a beehive spring, this is a DEFINITE answer. I have been through this with many customers in the past.
Old Oct 4, 2012 | 05:33 PM
Johnr352's Avatar
This is what we run on the race car. Greg's GSC S2's and Beehive springs and retainers. Love the cams, as they produce too much power for our hp to weight requires us to pull timing and boost. And, (it's a secret so don't tell anyone), I've missed a shift here and there. Not often mind you, but it has happened and, to date, (cross your fingers) no issues with a fast spike to 8500 before I catch it. I think his springs make all the difference in keeping those valves from becoming extremely angry when I happen to find 3rd instead of 5th for a half an instant on the downhill to T6 at WGI. Again, if you say anything...I'll deny it...
GSC - great cams.
Old Oct 4, 2012 | 05:40 PM
Blue91lx's Avatar
There are quite a few people (including myself) who ran/run S2s on BC springs/retainers without any issue whatsoever. I personally wouldn't worry about it. Just my .02.
007WRX
13
Apr 20, 2013 09:42 AM
subrwho
Feb 2, 2008 09:38 AM
spragueevo8
20
Dec 9, 2006 05:36 PM
