idle creep
Old Nov 22, 2012 | 06:03 PM
  #31
latreille's Avatar
Still stalling, NEED HELP im running out of ideas.
Old Nov 24, 2012 | 04:51 AM
  #32
latreille's Avatar
Wold the throttle seals cause some stalling when just advancing quickly, I am realy out of ideas. I also read it could be my ets ic piping short route. Anyway im pulling my hair out here trying to figure it out. Does anybody know when stated cold what should my rpms go to. Mine go to 2500 or so and then start to fall off. Any info apreciated.
Old Nov 24, 2012 | 12:32 PM
  #33
dastallion951's Avatar
What's your tps voltage reading? Can you datalog the car??? If so then when you adjusted the biss screw did you use a laptop as well. Or just manually do it??? You could've damaged your tps sensor too when u cleaned the tb.... Or your stalling issues are because the biss screw was messed with so your idle is all jacked up. I would say check those things worse case put on a new tps with that tb... Good luck
Old Nov 24, 2012 | 01:44 PM
  #34
latreille's Avatar
No dataloging here. Thinking the shaft seals is a bigger deal than I thought. plus my throttle plate is not well sealed either.
Old Nov 27, 2012 | 11:42 AM
  #35
3011carlos's Avatar
A friend of mine had the same problem and it ended being a Bad o2 sensor
Siluck2
11
Apr 11, 2016 06:06 PM
josephcastelar
Apr 22, 2013 11:37 AM
latreille
Oct 25, 2012 04:11 AM
eag36
27
Dec 9, 2009 07:06 PM
tgeo
Jul 27, 2009 08:41 PM
