idle creep
Old Oct 26, 2012 | 03:54 AM
latreille's Avatar
idle creep
My idle seems to creep up from about 900 to 1300 and then come back. Its not loping. Any ideas im thinking boost leak but not sure ? Any input is apreciated.
Thanks
Old Oct 26, 2012 | 04:15 AM
rocafellavc's Avatar
Mine is doing the same thing. It threw a iac code and I replaced it but still getting same issue. I've adjusted the biss and still getting no change. Gonna try and clean the maf today and see I that makes any difference.
Old Oct 26, 2012 | 04:56 AM
latreille's Avatar
I also cleaned the maf changed the iac and bov nothings worked.
Old Oct 27, 2012 | 01:45 PM
latreille's Avatar
Bump Still looking for advice
Old Oct 27, 2012 | 03:50 PM
i did a boost leak test at the shop here and found a very slight leak from the throttle body seals but they(and i) are convinced that it is not causing the issue. im stumped
Old Oct 27, 2012 | 05:28 PM
slowonder's Avatar
mine will do that with the defrost or a/c on. it doesnt creep though it jumps up to 1200 then when the compressor shuts off it drops back to 800.
Old Oct 27, 2012 | 06:15 PM
latreille's Avatar
i ordered seals so il take the tb off and clean it out realy good, im running out of ideas. il post the results when i get the parts next week.
Old Oct 27, 2012 | 06:52 PM
ChUt26's Avatar
Not sure if Evo's are the same as DSM's, but you can't adjust the biss by simply opening it or closing it. You have to ground something out for it to properly adjust.
Here is the guide for DSM's
http://vfaq.com/mods/BISS-2G.html
Old Oct 28, 2012 | 05:22 AM
latreille's Avatar
Il look into that. Thanks
Old Oct 29, 2012 | 06:28 AM
When yours creeps does it drop to low rpm like it wants to stall out? Or drops like normal but then started to creep? Mine drops like it wants to stall fixes itself then creeps up then back ill see if I can take a video and show you
Old Oct 29, 2012 | 02:02 PM
Chriskeatingix's Avatar
Thanks
What modifications have you done to your car one of them may have created your problem?
Old Oct 29, 2012 | 02:04 PM
latreille's Avatar
mine comes down to 900 rpm and then creeps to 1200 for a second and comes back to 900. but my car will stall the odd time when moving forward in a drive thru where your on and off the clutch quickly. Only mods I can see are short route ets ic piping a disconnected manual boost controller, Other wise I think the car is stock, The car idles at 17 inches of vaccum and makes 21 pounds of boost and tapers back to about 17 lbs.
Old Oct 30, 2012 | 11:39 AM
Here is a video of what mine is doing. I'm running out of ideas. Adjusted the biss and all that did was cause it to stall when the rpm drops down heavy like in the video where it dropped to under 800 rpm. Any other suggestions?
My mods are
Ams ic
280 cams
Intake
Buscher turbo back exhaust (straight pipe)
Mbc currently set at 20psi
Old Oct 30, 2012 | 05:31 PM
latreille's Avatar
You have a check engine light, do you know for what, that could realy help you. my idle is nothing like yours but i have no cel on. let me know what the code is.
Old Oct 30, 2012 | 06:43 PM
the code is for the secondary o2 sensor. it had an idle air control code and i replaced it and the code hasnt come back.
