Mystery harness behind pass. side headlight
Old Jan 11, 2013 | 06:05 PM
TommiM's Avatar
In that pic that connector looks like it has some bad corrosion. That will need to get cleaned up or better yet just replace that connector with a new one. Its pretty straight forward so long as you can find one from the dealer or a used harness. How does the other connection look? So long as the connection at the headlamp assembly are good then all you will need to do is put a new connector on. I doubt that the leveling motor is bad.
Old Jan 11, 2013 | 08:32 PM
R. Burgundy's Avatar
Both parts have a lot of corrosion. I don't know with my luck if I could find another harness though. Ill take it off and clean it the best I can but I doubt it will work.
If by the off chance I find some one parting out their car or something I'll get it but I doubt Ill find one. Does mitsuparts stock this? The nearest Mitsu dealer to me is about 1.5 hrs haha.
Old Jan 12, 2013 | 07:35 AM
Ryuartz's Avatar
I have seen some members unplugged harness on purpose because low beams move up and down by itself due to a bad leveling motor or bad manual adjustments. Hopefully nothing major. It could be a harness. I would bring it to local mechanic and see what they can do about it. Good luck and keep us update.
here is how to adjust manually. Hope this helps.
https://www.evolutionm.net/forums/ev...djustment.html
Old Jan 12, 2013 | 07:41 AM
Craig King's Avatar
This.
My guess was it was unplugged on purpose.
Old Jan 12, 2013 | 01:24 PM
en1gma's Avatar
According to the manual, it is plug A28
(spare connector for Fog Lights)
My guess is it is a spare connector
Old Jan 14, 2013 | 05:59 PM
Huh, never heard of that! I have an 03 if that applys? I'm guessing it was unplugged on purpose as well. There's no other reason to unplug it I feel like.
That link did help though thank you. I'm gonna plug it back in for now, adjust the lights manually and just forget about it. If I come across a harness then I'll fix it otherwise I just dont care enough haha. I don't need to adjust my headlights more than once, ever.
Thanks every one!
Bike Mech
Evo X How Tos / Installations
39
Mar 6, 2025 03:47 AM
xXANCHORMONXx
Apr 5, 2024 01:01 PM
a.care138
Oct 31, 2013 11:15 AM
s.e.a.n.
Aug 21, 2013 12:08 PM
