Evo VIII Using Oil + Black smoke on Start up
Old Mar 17, 2013 | 05:33 AM
JHS VIII's Avatar
I have done a good bit of research on this topic but found none that matches mine.
Well I have a 03 evo 8 fq300 with 330 piggyback ecu. It has 61000 miles and it also has a stock motor. The only upgrades I have is an apexi induction kit and evo 9 gt turbo.
About a year ago I had the head gasket replaced, and while the mechanic was doing it he replaced valve seals and cam seals. There was no problem with the head gasket since then that I can see.
I have also upgraded to the evo 9 turbo recently, about 900 miles ago. There was two main reasons I did this, I found the car was using a bit too much oil and thought of upgrading the turbo for reliability.
I though the old turbo might have had bad seals and thought the new turbo would have helped but it doesn't seem to have The car is still using a bit too much oil according to a mate of mine that deals with evos and I can see his point.
On start ups there is whitish kind of smoke but it normal, however if I rev the car especially when its not fully warmed up a lot of black smoke comes from the exhaust. I know you shouldn't rev a car when its cold but I give it a few mins. Also when I hit boost for the first few times after start driving it launches black smoke. It seems like oil is seeping down into the cylinders, would I be correct? I had a compression test carried out on the car and all cylinders have prefect compression.
Any help is appreciated guys
Old Mar 17, 2013 | 05:48 AM
todd6027's Avatar
Too rich will cause bore wash which in turn causes oil consumption .
Old Mar 17, 2013 | 08:42 AM
JHS VIII's Avatar
I was told that my ecu is locked on account of the factory upgrade, any info on this?
Cheers
Old Mar 17, 2013 | 08:59 AM
kanovic's Avatar
I don't drive mine daily usually just in the weekend and mine is the same way. If I get on it While it has been sitting for a while i get black smoke, but once it clears out then it's fine. I figured it was normal lol.... Mine does not use oil though.
Old Mar 18, 2013 | 11:17 AM
todd6027's Avatar
Cheers
can be unlocked get rid of the piggy back and get it mapped, where are you located .
Old Mar 20, 2013 | 02:41 PM
JHS VIII's Avatar
I pm'd you there
Old Mar 22, 2013 | 12:53 PM
todd6027's Avatar
returned
boost556
29
Sep 1, 2017 01:34 PM
dumpdbasethound
Oct 9, 2015 02:18 PM
sgambino92
19
Mar 6, 2013 05:29 AM
mmmmbst
34
Apr 14, 2009 03:06 AM
Evolessfornow
20
Mar 18, 2009 09:28 AM
