Overheating on idle and low speeds?
Old Apr 24, 2013 | 12:09 PM
88888's Avatar
Unhappy Overheating on idle and low speeds?
after attending a track day with my evo, i noticed my OEM water temp gauge (in the dash) has become way more sensitive than it has ever been before.
Some symptoms are
1. Car started over heating during track day for the first time. (oil tempo at 260) and water temp gauge 3/4 full
2. Car over heats on idle.
3. radiator fan seem to not be working
1 What could cause my motor to get hot suddenly? (both on idle and during movement)
2 what could cause my fan not to turn on anymore on idle?
any comments/ suggestions would be appreciated
thanks
Old Apr 24, 2013 | 12:28 PM
Ev0ikon's Avatar
Stuck/Defective thermostat would be my first guess.
Old Apr 24, 2013 | 12:42 PM
ReignMan24's Avatar
Check your thermostat and you may also have a blown headgasket. I had the same issue after a tuning session, tried replacing the thermostat turned out to be the headgasket, good luck.
Old Apr 24, 2013 | 12:54 PM
mdsevo06's Avatar
Get a block tester to start with, before throwing parts at it or any speed shop in your area should have one.
Old Apr 24, 2013 | 01:23 PM
88888's Avatar
[QUOTE=ReignMan24;10776183]Check your thermostat and you may also have a blown headgasket. I had the same issue after a tuning session, tried replacing the thermostat turned out to be the headgasket, good luck.[/
how do i detect a faulty thermostat?
are you talking about pressure testing the motor?
thanks
Old Apr 24, 2013 | 01:35 PM
sadc's Avatar
[QUOTE=88888;10776257]
thanks
Take it out from the car. Most manuals have instructions on how to. Throw it in boiling water and if it opens up once its boiling, then you know it works. If not or it only opens slightly then you know its detective.
Old Apr 24, 2013 | 06:19 PM
88888's Avatar
[QUOTE=sadc;10776280]
ok. i will get on that.
is this the only reason why the fan wouldnt turn on?
Old Apr 24, 2013 | 07:23 PM
batty200's Avatar
With a blown headgasket an air pocket around the fan temp sensor can cause a fan to not turn on. A block test willtell you if combustion gases are in the cooling system.
Old Apr 24, 2013 | 07:50 PM
barneyb's Avatar
There's another thread here with the same issue and some good ideas. 1. Not having the ground - manifold to firewall can cause this. 2. Log the temperature the ECU is seeing. If the ECU thinks everything is normal it probably is and the gauge sensor is faulty.
I wouldn't start thinking head gasket until coolant is dumping on the ground.
Old Apr 24, 2013 | 07:57 PM
detroit pistins's Avatar
u beat me to it!
https://www.evolutionm.net/forums/ev...r-heating.html
I just replaced my headgasket so I am hoping its the grounding wire I am missing and not have to pull off the head again
Jun 13, 2013 08:40 PM
dsevo
14
Feb 22, 2012 09:19 AM
Bones_OZ
Lancer Engine Tech
31
Oct 29, 2011 07:51 AM
evodrivesme
14
Sep 24, 2007 10:27 AM
jnathan68
Jun 10, 2007 04:44 PM
