Boost leak test
Old May 15, 2013 | 11:11 PM
bryonboals's Avatar
Boost leak test
Has anyone on here try to use a fog machine to check for boost leak? I got a fog machine in my halloween props and was thinking of using it to check for boost leak since I am not getting boost
Old May 15, 2013 | 11:12 PM
bryonboals's Avatar
I have heard of fog machine used for vaccume test
Old May 15, 2013 | 11:58 PM
luis!'s Avatar
I use fog machine in Halloween
Old May 16, 2013 | 01:44 AM
MrJuls's Avatar
Old May 16, 2013 | 09:20 AM
ProPilot04's Avatar
No. Do not use a fog machine to check for boost leaks. And do not use a fog machine to check for vacuum leaks.
If you're having trouble doing a boost leak test, get a spray bottle and fill it with soapy water. Spray it on every joint, charge, and look/listen/feel for bubbles.
Tighten and repeat.
A fog machine prop is going to cause more damage than it would repair.
A proper vacuum leak should be detected by using propane. Not starter fluid. Not a fog machine. Not a smoke machine.
Old May 16, 2013 | 10:21 AM
bryonboals's Avatar
Thanks
Old May 16, 2013 | 10:37 AM
nirvancol's Avatar
Tighten and repeat.
Good advice. Have any tips for checking the small lines behind the motor or any other connections that cannot be reached with a spray bottle? Sometimes I think I hear leaks, but I don't feel any air...
Old May 16, 2013 | 10:58 AM
MrJuls's Avatar
Pressurised air,spray soapy water...
Old May 16, 2013 | 11:36 AM
carpedro's Avatar
Tighten and repeat.
+1 for this sound advice
Old May 16, 2013 | 12:38 PM
ProPilot04's Avatar
For boost leaks? The only lines behind the motor I can think of off the top of my head would be the TB seals and the solenoids off the pax side of the intake manifold? Those should all be reachable. If there is more plumbing back there it would only be those little lines. Throw a ziptie around them, and tighten it? You can even put a thin layer of sticky grease over the nipple (hiyo!) to assist with the sealing.
If you're talking about vac leaks, I would HIGHLY suggest getting a hose on the end of whatever propane tank you're using. That way you can navigate it around to wherever.
Old May 16, 2013 | 04:55 PM
90zcrex's Avatar
If you are not getting any boost and you can't hear/see the leak then you are blind and deaf. J/K But seriously, if your missing those last 1-2psi then you need a soap bottle, if your not getting any boost and you don't hear a boost leak when running a correct boostleak test, then there's something else wrong besides a leak aka wastegate/boost controller/turbo.
Ferp
Apr 5, 2017 09:41 PM
pistons4550
Jan 13, 2017 11:35 PM
Shaun@AWDMotorsports
AWD Motorsports - Florida
20
Jun 14, 2016 10:39 AM
Evoguy!123
Apr 22, 2016 06:21 PM
NsinEvo8
14
Jun 23, 2009 06:10 AM
