Need your guys opinion on 2.3 13:1 CR build
Old Jul 11, 2013 | 02:06 PM
  #61
SmurfZilla's Avatar
ATTN: All ET FanBOI's
GTFO of this thread. If you want rave about ET's products and have your @$$ handed to you by people who have the knowledge then by all means start another thread about it but for the love of all thats holy stop cluttering the OPer's thread up with all this ET man love because no one is buying what your selling.
NO.
ONE.
You are preaching to people that are not going to listen. ET makes products out of unicorn foreskin I get it. Their pistons are crafted out of God's pubic hair. We get it.
ET is the greatest. They rock. THey are the greatest thing since whitebread. We get it now.
Can we tune back to the program we clicked on now, Please?
K, Thx, bye
Old Jul 11, 2013 | 02:23 PM
  #62
Migsubishi's Avatar
LMAO and um, yea + 250,000,000.00
Old Jul 11, 2013 | 02:27 PM
  #63
Migsubishi's Avatar
BACK ON TOPIC.....
DISCUSS????
Originally Posted by trfguy
We just got this yesterday from Wiseco for our Rally car. Hope they make a significant improvement in the 4G94's output!
Originally Posted by JohnBradley
A 14:1 or 15:1 boosted methanol motor is totally not the same as ethanol. They have distinctly different properties independent of octane rating. That aside, you can see the "edge" alot faster on a higher compression e85 motor. Lucas now has a 690whp FS635 setup on his 11:1 2.0L and it is obvious in the logs that it is at the edge based on noise. When the car goes back to the stock ECU we'll see what it looks like as far as if it was real knock or not (I have much to say on the AEM "knock" control but thats another thread). I think when we get to turbos that are in the 3586 range of airflow, they are so efficient that 29psi on pump with excellent timing isnt hard. I have run mine out to 32psi recently and it really looks like I can keep going if I didnt mind find the mechanical edge of the stock bottom end. I am sure we can run 13:1 on E98 without much of an issue, but what we do in a racecar versus what a "streetcar" is setup with are entirely 2 different things.
I am very much with David when he says that some of the best combos are not ultra high compression or "high compression" motors. Our 9:1 1G Eclipse seems to make alot safer power on the 4202 than the Evo does at only 10:1.
We have also found that the old hotrod rule of 4% per full point on a given setup holds true. The 3065 car mentioned at the outset made 633whp with 11:1 at 32psi versus the 580ish it made the year before at 9:1. There were some other changes made with respects to reciprocating mass that gave is some additional power as well as a cam change that later got us to 640+ before we were once again out of fuel.
I run big cams with high compression, here is an explanation
Originally Posted by 94AWDcoupe
The engine only cranks at 450 RPM. large duration cams hold valve open long enough to see a significant drop in air velocity at low RPMs. Thus less gets sucked in a low RPM. 450 is definitely low RPM. Put a small cam in car and watch cranking compression jump to 210 or so.
At high RPMs that long duration now allows more to enter chamber. This making more power at high RPMs.
The reason builders say high compression and large duration cams work hand in hand is because large duration cams give up large amounts of low end torque. you can get back some of that lost torque with the higher compression. second reason is increases in compression increase likely hood of detonation. detonation is most likely to occur at low piston speeds. so an decrease of air velocity (large duration) becomes welcome
yada yada yada
Old Jul 11, 2013 | 02:36 PM
  #64
SWOLN's Avatar
^^ What's that dimple all about there? ^^
Old Jul 11, 2013 | 03:37 PM
  #65
graphitegrey's Avatar
yes what is that?
Old Jul 11, 2013 | 09:52 PM
  #66
batty200's Avatar
The dimple is to show which way the piston should be installed. Dimple towards timing belt. It is because the piston is asymmetrical with an offset wrist pin.
Old Jul 11, 2013 | 10:46 PM
  #67
mrfred's Avatar
let me see if i understand this thread thus far - op asks for advice on a 13:1 cr motor, and several very respected members who have had high cr motors tell him its a serious mistake while at the same time et somehow finds about this thread and tells the op he's making a smart move. it even appears that et might be trying to sell him a motor. and the op is still planning to go ahead with it? am i right????
Old Jul 12, 2013 | 04:35 AM
  #68
SmurfZilla's Avatar
Naw. OP had the high compression seed by a shop that didn't know he could get custom pistons from any reputable piston maker and to get them from ET.
Once forum members started to tell him, 1). ET is not reputable, 2) Most piston makers will make what you need for way less the ET's unicorn foreskin, and 3). the proposed engine builder obviously doesn't have the experience based on advice given this far.
ET supporters came.out the wood work and hilarity ensued.
Old Jul 12, 2013 | 09:20 AM
  #69
stamatis evo6's Avatar
SmurfZilla relax
that thou shalt not every day we ET customer get multiplies by hundrends, sit down and enjoy it.
On beer on the house from me for my friend SmurfZilla. :b eer:
Old Jul 12, 2013 | 01:45 PM
  #70
SmurfZilla's Avatar
Thanks. I'm not as angry as the post would suggest or imply. Just have low tolerance for BS. My car giving me issues isn't helping what little tolerance I have left.
Old Jul 13, 2013 | 12:42 AM
  #71
AdrenalineRush's Avatar
Originally Posted by graphitegrey
yes what is that?
OP tell us what State you live in so we can get you better help. ET blows, so does the person who wants to build your car. There are numerous shops in the Midwest who could do your car without sweating and it will last!
Whether their parts are truly good is beyond the point. You don't need to reinvent the wheel brother just go with what's proven and you will absolutely not be disappointed.
Old Jul 15, 2013 | 05:36 AM
  #72
after build is said and done i will potentially say what shop it is.So more bad news, the crank has a slight crack in it and those k1 rods are only good for up the 700 hp...more money has to be spent now =(
Old Jul 15, 2013 | 06:09 AM
  #73
Migsubishi's Avatar
wow, sorry man.
Old Jul 15, 2013 | 06:40 AM
  #74
SmurfZilla's Avatar
That sux. Been there.
Old Jul 15, 2013 | 07:13 AM
  #75
im gonna go with manley turbo tuff rods and stock crank. anyone know hp capabilities on those rods and has any ever been able to make big power on stock crankshafts without engine becoming a crimescene?
