Actuator issues
Old Jul 28, 2013 | 06:13 PM
amsevokid's Avatar
Actuator issues
Just got done replacing my oem actuator with a forged performance one with the 14-18 psi spring in it. i started my car but the idle sounded a bit weird and the car would break up alot trying to rev so i figured i needed to adjust it, so after adjusting it the opposite way that it was originally the car shows the same symptoms. any suggestions?
Old Jul 28, 2013 | 07:05 PM
gpfury86's Avatar
Vacuum lines all hooked back up correct? Did u set the preload correct on the arm? Any check engine lights on?
Old Jul 28, 2013 | 07:13 PM
amsevokid's Avatar
all vacuum lines are ok, i only took off the one from the actuator and my check engine light is on since i put on my straight pipe i made. could it be possible to have the two lines from the actuator and turbo mixed up? and i dont know how to set it bc right now its in the position from when i first got it, how do i adjust it beside turning the turnbuckle or is there a certain amount of turns to do?
Old Jul 28, 2013 | 08:45 PM
amsevokid's Avatar
just adjusted the turnbuckle a full 3 turns and now iots works great except im boosting at 16psi, should i do a boost leak test? or maybe try reconnecting my stock mbc?
Old Jul 29, 2013 | 04:26 PM
ChristianAPEX8's Avatar
^ He is correct
Old Jul 30, 2013 | 08:21 PM
amsevokid's Avatar
Originally Posted by ChristianAPEX8
^ He is correct
which part am i correct about? the boost leak test or switch to my stock mbc?
EvilDSM97
Feb 2, 2017 10:51 AM
Mattevo4
Dec 19, 2014 04:49 PM
jason42003
Sep 25, 2014 07:18 PM
steven121
Aug 26, 2013 11:34 AM
mscorei
20
Mar 5, 2008 06:45 PM
