Compression Test results HELP diagnosing
Old Sep 17, 2013 | 02:23 PM
r3dtr1ckz's Avatar
So after doing a 2nd gear pull the other day, lots of coolant hit the windshield and of course a ton of smoke. So after taking a look i see the radiator is leaking at the top by the welds. Did a compression test, came back 180, 90, 176, 179. Cylinder 2 very low, theres no coolant when checking the dipstick. Im leaning towards a compression ring maybe, any ideas?
Old Sep 17, 2013 | 02:31 PM
SDevo13's Avatar
You probably lifted your head/blew your HG seal around the low compression cyclinder and pressurized your coolant system. Are you missing any freeze plugs?
Old Sep 17, 2013 | 02:36 PM
r3dtr1ckz's Avatar
no, not missing any freeze plugs.
Old Sep 17, 2013 | 07:02 PM
r3dtr1ckz's Avatar
Bump
Old Sep 17, 2013 | 07:04 PM
Jwhalen07's Avatar
You can just leak pressure into the coolant without mixture of oil. You will need to replace the headgasket. Obviously your building a ton of pressure in your cooling system with the leaking issue your experiencing.
Old Sep 18, 2013 | 03:37 PM
r3dtr1ckz's Avatar
also noticed this space here, tell me what you think of this.
Old Sep 18, 2013 | 03:55 PM
Czarcasm's Avatar
Looks as if someone had the tbelt cover off and cracked the plastic. Notice the small hole? Thats where the tool for the tbelt tensioner goes.
Old Sep 18, 2013 | 05:35 PM
r3dtr1ckz's Avatar
So thats no big deal then? Wasnt sure when i seen it.
evole97
14
Nov 10, 2021 08:06 AM
evovin
73
Mar 12, 2018 12:18 PM
megamind
17
Nov 3, 2017 07:01 AM
ISPEVO8
Feb 27, 2017 07:01 PM
unknown2
14
Sep 21, 2006 09:42 PM
