turbo help
Old Oct 2, 2013 | 01:35 AM
marceloevo's Avatar
Oo ok then thats alot man for your help because the people that ive been talking to here r just basically tellin me to get the ams kit and that kit is really expensive, and since theres alot of smaller bolt on turbos on the market I became so confused on what turbo would fit my needs
Old Oct 2, 2013 | 01:37 AM
b00stah0lic's Avatar
You bet man. I sent you a private message if you want to check that.
Old Oct 2, 2013 | 02:19 AM
e_kobz's Avatar
Do not get the a.r.m.s., HKS, or any other JDM stock replacement turbo for the evo. they don't hold up like the FP, MAP, or CBRD turbos do. no to mention you have the opportunity to help a company, that's always a bonus. the other big benefit to running one of FP, MAP, or CBRD's turbos is in case something ever does go wrong they're just a phone call away and all three places have awesome customer service and they stand behind their product. Try getting a Japanese company on the phone not to mention their customer service is horrible most of the time.
And in regard to what turbo will fit your need(s) just ask yourself this one question: do you want quick spool and response or do you want top end power. On pump it's hard to have both, on E85 it's relatively easy.
Old Oct 2, 2013 | 02:20 AM
^ Hit the nail on the head
Old Oct 2, 2013 | 03:43 AM
JaYr_EvO9's Avatar
Yep what he said
Old Oct 2, 2013 | 11:36 AM
CBRD's Avatar
we can also do the ball bearing BBK full
cb
Old Oct 2, 2013 | 11:45 AM
sujinX's Avatar
ball bearing bbk full
/thread.
Old Oct 3, 2013 | 12:18 AM
marceloevo's Avatar
The bbk full is exactly what I want but im afraid that awd wouldn't b able to tune it since there used to tuneing fps. Would I have to send my turbo to cbrd to get it built to a bbk full
Old Oct 3, 2013 | 12:40 AM
Your shop will be able tune for it, do not worry about that part. If they can't or refuse to, you need a new tuner.
I know FP lets you either buy brand new or send your turbo in. Im not sure about CBRD
Old Oct 3, 2013 | 12:57 AM
marceloevo's Avatar
When installed, does the cbrd look stock or would you able to tell that you have a turbo upgrade and would I b able to install a extenal wastegate wit the bbk
Old Oct 3, 2013 | 02:34 AM
You can run an external wadtegate with any stock frame turbo, yes. You would need to get a different o2 housing with an external wastegate flange. I believe MAP sells them. It is a stock appearing turbo but there are differences a well trained eye can see if they look close. The biggest give away is the blue compressor wheel.
Old Oct 3, 2013 | 08:30 AM
CBRD's Avatar
our turbo looks completely stock--
I dont believe in using the external gates on stock turbos---- most of the o2's have the WG post turbine which adds un-needed volume to the turbine housing and then creates lag-
We can modify a stock IX turbo or build a new one- and they look 100% oem when installed on the car
cb
LancerRacer01
Jun 22, 2016 01:34 PM
mrhoward
15
Jul 15, 2015 10:48 PM
boostin@27
14
Jan 8, 2014 05:11 PM
airman9911
33
Nov 5, 2013 01:01 PM
JDM_Specialty
Asian Forum
Apr 10, 2006 02:14 AM
