Whining T-Case is it safe to drive long distance?
Old Jul 11, 2014 | 05:31 PM
  #31
RedAustinIX's Avatar
So the next question (because I fear that I may be in the same situation) is, when getting it replaced should we go for a Mitsubishi replacement, or opt for a Jacks rebuilt? It sounds like the failure may be power-related, so for those of us with simple bolt-ons and tunes (i.e. 100-150hp over stock) is a Mitsubishi replacement just going to break down again in a couple of years?
Thanks!
RedAustinIX
Old Jul 11, 2014 | 06:30 PM
  #32
RussellDaniel's Avatar
Thanks!
RedAustinIX
To do a oem replacement rebuild Jacks offers that as well as TRE and Shep. Then you get into the stage 2 and stage 3's. If you have a Evo 8, you could use the LSD front diff upgrade, if you have a Evo 9 and your not wanting to push it much farther than stock then just doing a stage 1 with new ring and pinion (if needed) should be fine.
Old Jul 11, 2014 | 10:36 PM
  #33
oscarquinones's Avatar
I recommend you to go jack, shep don't go to the dealership. There are the best and they will help you find the best set up for you.
tdusffx
Sep 10, 2015 11:18 PM
Icegod87
Oct 21, 2014 11:15 PM
Jesussaves1
Mar 11, 2013 02:38 PM
Evo11V
12
Jun 7, 2012 04:29 PM
Don Q
May 10, 2012 08:11 PM
