Service engine soon light
Old Oct 14, 2014 | 05:04 PM
ID #376's Avatar
Here's my setup, I have a 2006 EVO IX with the following, head has Kelford 280's spring & retainers, a Magnus intake, ID 2000, high flow fuel rail, I have a 4G64 Destroked 2.1 with 10:5.1 compression GRP rods, twin AEM E85 fuel pumps, PTE6766BB Turbo at 31PSI, AEM series 2 & it runs on E85.
My question is as my car passes 7000RPM on WOT the "Service engine soon" light comes on & was wonder why that happens?
Old Oct 14, 2014 | 11:21 PM
novem's Avatar
Mil flashing for OBD II cars indicates misfire. If your car was tuned to flash knock count, that would be the second reason. You did not say if the MIL flashes..or if you had a DTC.
N.
Old Oct 15, 2014 | 11:18 AM
EatSleepBoost's Avatar
Also he is on AEM though. Posting this in the AEM tuning section would net you better results as almost all of us run oem ecu. A check engine light coming on but only at high RPM would make me think the AEM is using the light as a "shift" light to indicate when to shift so you don't have to watch your RPM's. Also as stated above could be engine knock but I would expect the light to flash if that was the case.
Old Oct 15, 2014 | 12:12 PM
slowsrt4:('s Avatar
maybe knock?
Old Oct 15, 2014 | 06:44 PM
ID #376's Avatar
Sorry for posting this in the wrong section but you are right, it's a shift light. Thank you guys again for your replies.
Az3ar
Jun 16, 2004 11:05 PM
Lancer408
Lancer Troubleshooting
46
Sep 30, 2003 07:07 PM
ChillinEvoVIII
10
Jun 28, 2003 01:45 PM
IS2000
14
Jun 9, 2003 08:25 AM
BostonLancer
10
Aug 26, 2002 05:41 PM
