Evo starter
Old Dec 23, 2014 | 09:48 AM
ryan78's Avatar
Evo starter
Hi fellas. I was just wondering why my Evo VIII would still not start after installing a new starter. Any thoughts on this issue?
Old Dec 23, 2014 | 09:49 AM
Evolution7GSR's Avatar
are all of the grounds hooked up correctly? is it new or a re manufactured starter?
Old Dec 23, 2014 | 09:52 AM
ak47po's Avatar
Did you disconnect your battery before install?
Old Dec 23, 2014 | 10:28 AM
brunz44's Avatar
Check small black wire on the starter wiggle it some an try to start it
Old Dec 23, 2014 | 12:03 PM
ryan78's Avatar
From what I know, all the grounds are hooked up correctly and it's a new starter that was installed. Yes, the battery was disconnected during the starter install. My mechanic tried to wiggle the black wire when I was starting my car yesterday and still, it takes me more than several tries before my car starts.
Old Dec 23, 2014 | 12:31 PM
Biggiesacks's Avatar
put a meter on the signal wire and make sure its getting 12volts when you turn the key to start. If not then trace it back could be a fuse or even the ignition switch.
Old Dec 23, 2014 | 02:39 PM
ryan78's Avatar
Thanks for the input guys.
Old Dec 23, 2014 | 03:01 PM
I wouldn't be surprised if it was related to the ignition switch. I had to replace my ignition switch a while back with the same symptoms you are having. You can actually take it apart and clean it, but it was cheap enough that i just bought a new one.
Old Dec 23, 2014 | 03:51 PM
Bhsj13's Avatar
if the starter is good to go with the bolts tight then i think like ^^ might be ignition switch related.
Old Dec 25, 2014 | 01:51 PM
ryan78's Avatar
Problem solved, guys. It was indeed the ignition switch that was the problem. It has been replaced with a brand new one and now, my evo has no problems starting again. Thanks again for all your input.
ru4real
Jun 27, 2016 10:14 AM
nor11384
Feb 20, 2016 05:06 PM
Routybouty
Nov 25, 2010 04:13 AM
justa4banger
Dec 4, 2009 11:20 AM
Evokid03
May 14, 2009 08:53 PM
