Engine and tune questions
Old Dec 28, 2014 | 07:53 PM
amsevokid's Avatar
Sorry for the newb questions but I need some help.
Questions
My car has never been tuned and I'm in the process of doing a couple mods to it.
What mods I have-
Stm uicp short route
Ets licp
Aem fuel rail
Walbro 255 pump
Hallman mbc
Ported intake manifold
Ported throttle body
Borla exhaust manfold
Vrsf 3.5" fmic
Ets intake with maf
Full straight pipe exhaust
Deleted egr
Mods to be done
E85
Gsc s2 cams
Supertech springs and retainers
Fp jb black
1200cc Injectors
Speed density
Forged internals
Shepard trans
Exedy clutch
Stm ss clutch line
Now here's the thing, would the tuner be able to tune the car with the new forged internals when the haven't been broken in yet?
Old Dec 28, 2014 | 08:04 PM
okevolutionVIII's Avatar
The only thing that really needs to be broken in is the piston rings. Has to be done properly as soon as the engine is 1st started. After the break in and an oil change to a proper weight, synthetic oil then the engine is ready for WOT tuning.
Old Dec 28, 2014 | 08:07 PM
amsevokid's Avatar
Right now the car is in my car port while if do these mods to it, my plan was to do everything including the engine internals then have it tuned. So would the tuner be able to tune it without dynoing the car just so I could drive it nicely until it's ready for a real tune? That way the car is drivable so that I can put the miles on it to properly break in the motor?
Old Dec 29, 2014 | 07:39 AM
thepoint4life23's Avatar
Most Tuners can give you a break in tune. with low boost
Old Dec 29, 2014 | 01:55 PM
amsevokid's Avatar
Thank you, that's exactly what I needed to know. Would they also be able to delete the egr in the computer as well?
Old Dec 30, 2014 | 06:45 AM
they can turn it off in the ecu takes no time at all.
who is tuning your Car?
Old Dec 30, 2014 | 02:21 PM
illusin's Avatar
Break in of the motor is dependant on who you ask, some say no boost till 1k miles with variable RPMs ect and some say drive it like you stole it. I do have a small suggestion you may want to consider going bigger on the injectors now rather then waste the money later down the road. Just a suggestion also your 255 will be maxed out around 480-500 hp .
Old Dec 30, 2014 | 02:29 PM
VerbalKilla's Avatar
we have a similar set up.. I would recommend going bigger on injectors.. Contact MAP they gave me a good deal for 1120cc FIC's. Also.. I also had the walbro 255 and went too the Walbro 400 LPH Pump. They say it is made for e85, I can tell you I have NOT had any problems with it and will save you the upgrade in the long run or worries of maxing it out for about $60.00 more...
Old Jan 3, 2015 | 06:49 PM
amsevokid's Avatar
That's great and a local place called chameleon tuning will be tunning my car
Old Jan 3, 2015 | 06:53 PM
amsevokid's Avatar
What do you think about dw1300cc injectors with the 400lph pump
Old Jan 3, 2015 | 06:55 PM
amsevokid's Avatar
I found some dw1300s what about tose? They are good for e85 and are plug and play.
Xenozx
11
Aug 1, 2012 08:03 AM
jrsimon27
69
Oct 22, 2007 01:42 PM
hellview
Sep 16, 2007 06:13 AM
EVO8URV8
17
Oct 27, 2006 02:51 AM
majestic lancer
Oct 13, 2003 07:02 PM
