PO300 Code , Help Please
Old Jul 1, 2015 | 11:04 AM
djelliott978's Avatar
Changed, Plugs, Wires & Coils,
Car pulls fine in 1 & 2nd but hesitating in 3rd & 4th gear, compression 180 across, could it be a cat or Egr Issue
Old Jul 1, 2015 | 11:37 AM
Ev0ikon's Avatar
What brand plugs and what gap size?
Old Jul 1, 2015 | 02:56 PM
I got the plugs from the Mitsubishi dealer & not sure of the gap i had the dealer gap them
Old Jul 3, 2015 | 04:45 PM
CDrinkH2O's Avatar
P0300 shows that a random misfire happened on more than 22 of the last 1000 engine revolutions during the last drive cycle. Look at the following possible causes in sequence. The most likely are shown first:
1. Check your plug condition/gaps, leads (no breaks in insulation) and coils (no cracks and resistance < 19kOhms between lead end and coil plug connectors) and make sure you have a fat spark on each.
2. Check your crankshaft position sensor and trigger wheel are not damaged (missing or bent teeth) or dirty. It's behind the timing belt drive pulley on the passenger end of the crank shaft.
3. Check your AFR is not too lean or too rich (Long Term fuel trims are not greater than +/- 12.5 and Short term O2 trim not greater then +/- 20). This could be due to a boost leak or loose vac lines behind the intake manifold.
4. Check cylinder compression pressures are not below 138 psi
5. Check timing belt tension and make sure it has not skipped a few teeth.
6. Check your EGR valve has not failed.
Old Jul 6, 2015 | 02:15 PM
iin10ded's Avatar
nice tshooting list.
Old Jul 6, 2015 | 02:41 PM
Thank you guys much respect
Old Jul 8, 2015 | 06:27 PM
mt057's Avatar
If it is an Evo8 with no issues and you have given it a thorough check. Then have the code disabled.
unknown2
Sep 9, 2005 12:24 PM
BoostWhore
Sep 4, 2005 02:51 PM
nbpal4000
15
Mar 2, 2005 06:11 PM
nbpal4000
Feb 27, 2005 04:42 PM
5PYD3R
26
Mar 19, 2004 09:17 PM
