Mivec P0011
Old Nov 16, 2015 | 08:34 PM
  #31
Sheasta's Avatar
Originally Posted by CeliOnce
I'll feel pretty dumb if that's the case. Especially since I did a "minor" wire tuck when I rebuilt my engine.
Edit: OH MY GOD. I can't believe that. I owe you a beer or something.
I only knew because that was my problem.
Old Nov 19, 2015 | 09:07 AM
  #32
uneekvisions's Avatar
Yea my wires were fine so back to the drawing board for my code. My builder and I are thinking it might be in the tune. I have a dual map tune e85/93. So I'm gonna switch to the 93 map after I run through my current tank of E85 and see if it goes away. The tuner already dialed back the timing on the E85 map once, but I'm gonna have another tuner go through the tunes and see if the initial tuner missed something.
Old Nov 19, 2015 | 05:41 PM
  #33
Sheasta's Avatar
The maps can only go up to 28.8 degrees of advance so if it were over it would be hard to overlook. I'd go back to mechanical things if your wiring and solenoid are both good. Mivec filter, feed line, cam gear, check valve, and head passages.
Old Nov 23, 2015 | 10:28 AM
  #34
Yea after doing some research, the car uses the same MIVEC maps across the board so switching to my 93 tune didn't solve anything anyway. My builder is going to do some more mechanical testing and see if he can locate the issue on that level.
Old Feb 14, 2021 | 09:00 AM
  #35
Declan Sharpe's Avatar
Originally Posted by Sheasta
Best way to test this circuit :
1. Unplug mivec oil control valve / solenoid which is a 2 wire connector.
2. Key on engine off put the red lead if your multimeter on the red and yellow wire pin.
3. Ground the black lead at a known good ground.
If you have battery voltage the first half of your circuit is good.
4. With your positive lead at the red and yellow wire pin touch your negative lead to the other pin .
If you are loosing excessive voltage between the known good ground and the signal ground then you have a problem with the signal ground wire . If I t's battery voltage or slightly less then it is good.
If you get no reading using your signal ground then you either have an open between your connector and your ecu , or your ecu isn't grounding the circuit as it should and your ecu is bad.
Edit: make sure the connector has a red and yellow wire (12v) and a pink and black wire (ecu grounds this with car one engine off.)
this was a very good place for me to start, my yellow and red wire has 12v but pink and black came 0. I traced it back to ecu behind the dash and tried to measure voltage at the pin for the pink and black wire, still 0. Is it safe to try and repair the ecu, or should I just start searching for a new one?
Lazukard
18
Sep 11, 2011 09:01 PM
crckheadjed
Nov 21, 2010 02:59 AM
heaveho
25
Sep 10, 2010 10:02 AM
99octane
Feb 27, 2007 08:35 AM
Arithmetic
May 30, 2005 09:49 PM
