Please help
Old Dec 27, 2015 | 09:32 PM
MR.EVO00's Avatar
Please help
My throttle seems to rev up 300 rpms after letting off gas what gives any help would be greatly appreciated thanks
Old Dec 28, 2015 | 04:16 AM
FTONOOB's Avatar
Is it "mostly stock"? TPS probably?
Old Dec 28, 2015 | 04:47 AM
MR.EVO00's Avatar
Yes car has been the same way as far as mods go for a while without any issues of this happening . still stock throttle body stock turbo stock blow off valve stock wastegate.
Old Dec 28, 2015 | 05:49 AM
egis's Avatar
Check the IAC valve wire connection .
Old Dec 28, 2015 | 08:26 PM
MR.EVO00's Avatar
Where is the ischia valve? And thank you.
Old Dec 28, 2015 | 08:27 PM
MR.EVO00's Avatar
I I iac valve
Old Dec 29, 2015 | 02:13 AM
FTONOOB's Avatar
On the Throttle Body you have that IAC (Idle Air Comtrol) and the TPS (Throttle Position Sensor). The IAC is usually at the base of the TB while the TPS is on the side. IAC may need cleaning but check the TPS aslo.
Old Dec 29, 2015 | 04:20 AM
rogerlam's Avatar
I'm thinking ccould be sticky throttle cable or dirty MAF sensor.
Old Dec 29, 2015 | 07:06 PM
MR.EVO00's Avatar
Thanks will do I'll keep you posted
Old Dec 29, 2015 | 07:40 PM
Cal City Evo's Avatar
Clean your throttle body also. They get enough crud in them they can stick open enough to cause problems.
nlp187
Jul 8, 2012 10:32 PM
DIDYSIS
May 9, 2009 04:30 PM
AlliGirl
Northwest Region
Sep 17, 2003 12:55 PM
