Evo 8 non cdi sparktech question
Old Jan 9, 2016 | 02:28 PM
1fast97gsx's Avatar
I just received this and I'm wondering if this requires any changes to my tune or can you just put it in and you're good to go? It has different coil charge times / dwell times I'm assuming but is this something I need to address? Thanks.
Old Jan 9, 2016 | 06:45 PM
llDemonll's Avatar
put it in and good to go
Old Jan 10, 2016 | 07:12 AM
lostsoulsevo's Avatar
You need to change your 10A fuse to a 15A on the number 1 slot under the drivers side dash.
Old Jan 10, 2016 | 10:16 PM
evo.matt's Avatar
I heard this before, but what does it do? I have the spoolin up kit, which doesn't require it as far as I know.
Old Jan 10, 2016 | 10:22 PM
evo.matt's Avatar
I actually found the answer here https://www.evolutionm.net/forums/ev...n-cop-kit.html
Old Jan 11, 2016 | 08:15 AM
llDemonll's Avatar
Spoolinup is the same. They recommend a 15A fuse
Old Jan 12, 2016 | 08:24 PM
1fast97gsx's Avatar
Yea I changed the fuse, I was really more wondering if there was any tuning issues. I noticed the car has a higher / stronger idle than it did before it seems. When I come to a stop the idle will stay at 1300 rpm or so and then drop to the 1000 rpm its tuned for after about 10 seconds which before it seemed to drop almost right away. Any ideas on how I can change this? Nothing else was changed on the car.
Old Jan 12, 2016 | 10:25 PM
llDemonll's Avatar
ignition won't cause that, it's something else
masonh
Feb 16, 2014 10:59 AM
BoostWhore
Feb 16, 2014 10:57 AM
Nomad4g63
Nov 3, 2013 06:27 AM
BEISSEN
Feb 1, 2011 12:59 AM
