Cap turbo coolant lines?
Old Jan 22, 2016 | 08:55 AM
grim~'s Avatar
So this may be a stupid question but when i got my 6262 kit installed a few years ago the shop that installed it said that since my turbo is only oil cooled that they would run a hose that loops the inlet and outlet for the old turbo coolant lines. Well this past weekend that hose sprung a leak and puked coolant everywhere. I want to replace it but i was wondering if it would just be better to cap it than to loop it. What does everyone else do when they run a oil cooled only turbo?
Old Jan 22, 2016 | 09:17 AM
TheBoz's Avatar
Fix the coolant lines the correct way. But if you are in a bind and have to ghetto it, then cap the lines at the thermostat and I would zip tie the coolant lines from the turbo out of the way for now. This would be a temp fix to get you home.
Old Jan 22, 2016 | 09:18 AM
LetsGetThisDone's Avatar
You can cap them, it'll be fine.
Old Jan 22, 2016 | 10:45 AM
grim~'s Avatar
What would the correct way be? Also i think they modified my lines and cut them down, i can take a picture when i get home
What do you recommend i cap it with? I heard that the rubber caps wouldnt work.
Old Jan 22, 2016 | 11:50 AM
kaj's Avatar
kaj
my radiator hoses are rubber, they seem to work okay.
Old Jan 22, 2016 | 11:54 AM
Rubber caps will work fine. They do make specific ones for heater hose and bypass hose connections. They're thicker, use those. Don't use vacuum caps.
The guy saying to "fix it right" is I think not realizing that your turbo doesn't use water cooling.
Old Jan 22, 2016 | 12:02 PM
TheBoz's Avatar
Ahhh it is only oil cooled, my bad ignore my previous post.
You could weld on -6an fittings to the two ports and use an cap. Or you can pull the tstat and weld it shut and do the same to the water pipe.
Old Jan 22, 2016 | 12:22 PM
grim~'s Avatar
Thanks! Any idea where i can get those? ive looked online at various auto stores but i seem to only find rubber vacuum caps.
Old Jan 22, 2016 | 12:26 PM
grim~'s Avatar
i found these, might give these a try they say they are made for coolant pathways so should be resistant to the heat
http://www.autozone.com/cooling-heat...?checkfit=true
Old Jan 22, 2016 | 12:29 PM
kaj's Avatar
kaj
rubber caps are rubber caps.
my car was down for about a year with vacuum caps sealing my lines up. they should be fine. i'd check them once in a while for cracks, though; they may get warm LOL.
unless someone has a better cap to use, that is. i never really researched anything beyond the vacuum caps.
Old Jan 22, 2016 | 05:33 PM
Those are it!
Old Jan 22, 2016 | 06:05 PM
kaj's Avatar
kaj
yep, i have the same kit. those things are invaluable while working around the engine LOL. i didn't realize they were coolant-specific. now i'm curious. i'll have to go look at the box.
RallySport9
Feb 20, 2016 11:24 PM
blkmkIII
Jan 29, 2012 07:18 AM
varner88
22
Apr 1, 2010 07:56 AM
MikeyT
Dec 12, 2008 12:50 PM
xenoturkey
May 9, 2006 01:57 PM
