Hose from firewall liquid dripping
Old May 9, 2016 | 05:49 AM
henriklm's Avatar
Hi guys.
Is there anyone who can tell me what this hose from the firewall is ?
Its leaking some kind of liquid.
Thanks alot
Henrik
Old May 9, 2016 | 06:04 AM
Those 2 metal tubes connect to the evaporator core in the dash (AC refrigerant) (is it item 1 & 2?)
The other 2 tubes (rubber hoses) are for the heater core (radiator fluid)
Old May 9, 2016 | 06:05 AM
henriklm's Avatar
Thanks a lot, then it should be ok.
Old May 9, 2016 | 06:53 AM
henriklm's Avatar
I think its number 2, not sure tho. Can i smell it if its a specific fluid?
Old May 9, 2016 | 07:15 AM
barneyb's Avatar
Both heater core hoses connect in the engine bay, heater core tubes stick through the firewall. Both lines from the A/C connect in the engine bay, same story as above. I tried figuring out what I'm looking in your photograph but I can't. Please say where the camera was and at what angle it was held when the picture was taken.
Old May 9, 2016 | 07:20 AM
henriklm's Avatar
If you flip your picture 90 degrees to the left, you will have the strut bar on top and the intake on your left side of the picture.
Old May 9, 2016 | 03:48 PM
barneyb's Avatar
Lol, I thought I was looking at something under the dash.
On my 8 that area is bare firewall. From the factory, far to the right in the rotated picture and hidden in this view, is an unused hole through the firewall used by people installing accessories. I assume the big hose houses wiring that uses this hole. There looks to be several small hoses that I can't identify.
Old May 10, 2016 | 07:30 AM
njboy's Avatar
It's a right hand drive car right. ABS pump on the left?
Old May 10, 2016 | 09:50 AM
barneyb's Avatar
Bingo! Nothing I was seeing was making sense.
W_evo8
Jun 27, 2008 02:11 PM
EvoLife
Aug 16, 2007 06:09 PM
dennyt4
Jun 4, 2007 05:43 PM
expl0d
Jul 17, 2005 05:12 PM
buzntxn
Sep 22, 2004 12:36 PM
