Is -6 normal for idle vacuum?
Old Jul 15, 2016 | 07:57 AM
Tekniq's Avatar
Long story short....
I was having issues with my built engine shooting out the dipstick and shooting oil over the engine.
I saw Tscomptuned post here: https://www.evolutionm.net/forums/ve...ification.html
And decided maybe that could help my issue. While doing this modification on my own. I realized my original issue. The pcv was clogged. So I replaced that as well when I had the valve cover off.
Now that I have it back together. My vacuum has gone from -11/-12 to -6/7.
Is this because of the modification or do I maybe have a boost leak? Do I need to be retuned?
Old Jul 15, 2016 | 02:55 PM
Name User's Avatar
I had that issue when I skipped timing, -7 instead of -15.
Try to verify that, but also I guess feel for the common leak spots like the hoses to the EGR below the throttle body, FPR, FPR solenoid, etc.
Old Jul 15, 2016 | 03:12 PM
LetsGetThisDone's Avatar
-6psi is normal. -6inhg is not.
Old Jul 15, 2016 | 04:22 PM
Teal2nnr's Avatar
No such thing as -6 psi . Seems low OP, I would be looking for a leak. You could raise your idle to compensate, but I would do that as a last resort.
Old Jul 15, 2016 | 05:07 PM
EvoScan reads negative PSIG on the MAP sensor circuit. It's -6psig, which is 8.7psia where 14.7psia is 0psig.
And raising idle speed would not increase manifold vacuum. If anything it would lower (closer to 0psig) since you're allowing more air through the TB.
Thanks for playing.
Old Jul 15, 2016 | 05:29 PM
Tekniq's Avatar
So the consensus is nothing should have changed by freeing up crankcase pressure and I have a boost leak?
Old Jul 15, 2016 | 06:11 PM
Teal2nnr's Avatar
Thanks for playing.
All I said was there wasn't such thing as negative Psi (referencing absoulte). You answer more questions than anyone on here recently, I should have known to keep my mouth shut haha.
Old Jul 15, 2016 | 07:09 PM
Well, if the PCV was clogged, it could have increased vacuum in the manifold. Doing a boost leak test is always a good idea. Is the car running weird? Does it have aftermarket cams?
Old Jul 16, 2016 | 04:24 AM
Tekniq's Avatar
The car idles fine. I haven't driven it yet. It has Kelford 272s
Old Jul 16, 2016 | 06:45 AM
barneyb's Avatar
I tried replacing the PCV valve with aftermarket but found that only an OEM valve seals boost out of the crankcase.
Old Jul 23, 2016 | 02:05 PM
Tekniq's Avatar
FOUND TH PROBLEM:
Fuel injector seals where leaking.
Old Aug 2, 2016 | 12:14 AM
zbestevors's Avatar
Nice job. Cheap fix too
CJ2X
17
Nov 13, 2012 11:05 AM
MattyBoyMR
Mar 19, 2009 09:13 PM
Done
Aug 17, 2008 04:07 PM
PorkRoll
19
Nov 12, 2007 10:50 AM
BboyZ3ro
Apr 14, 2004 10:22 PM
