Noise when turning
Old Sep 2, 2016 | 05:21 AM
InitialE's Avatar
Noise when turning
When driving slowly and turning the steering wheel hard to the left there is a thumping metallic noise that seems to come from the front passenger side of the car. The noise is more pronounced when driving in reverse. The suspension and brakes were inspected and no problems were found. Any ideas about what the root cause could be?
Old Sep 2, 2016 | 05:31 AM
lancerrally45's Avatar
wheel bearing?
Old Sep 2, 2016 | 05:56 AM
CaptainSquirts's Avatar
Have you tried shaking the tire up and down, side to side? Also using stock strut mounts and if so how many miles on em and are the rubber cracked on em?
Old Sep 2, 2016 | 06:10 AM
InitialE's Avatar
The strut mounts on the front were replaced maybe 4 years ago. They could be bad already. Thanks for the suggestion.
Old Sep 2, 2016 | 06:11 AM
InitialE's Avatar
Originally Posted by lancerrally45
wheel bearing?
Thanks for the suggestion. Any sort of testing you think can be done to determine if that is the issue?
Old Sep 2, 2016 | 09:32 AM
Ferp's Avatar
Get your front passenger tire, where the noise is coming from, in the air and place your hands on the tire at 9 and 3 and shake back and forth, then put them at 12 and 6 and shake up and down. It shouldn't move. If it's moving you typically have a bad wheel bearing.
Old Sep 2, 2016 | 09:47 AM
What the Canadian said ^^
fatalbert69
Apr 3, 2005 06:57 PM
dpwurzer
Feb 26, 2005 01:30 PM
AmOniaK
Lancer Troubleshooting
18
Nov 27, 2004 04:07 PM
rExTuHfEr
Jul 29, 2004 09:59 AM
VIII
Aug 5, 2003 05:01 AM
