Help, Deceleration noise rattle evo viii
Old Sep 9, 2016 | 11:22 AM
meckert's Avatar
Have a bad rattle on deceleration around 3k + in rear. Read thru every threat, checked everything--found a few issues with the exhaust but still have a problem I cant find. No noise under load on acceleration, just a rattling noise on deceleration, the higher the rpm the louder, take the car out of gear and no noise. Have urethane exhaust mounts, diff mounts, solid drive shaft mounts - no clearance issues with the exhaust anywhere. Urethane rear suspension bushings in all the rt places-- no broken swaybar links, no binding no rubbing I can see. Checked the cat to be sure it wasn't broken up--its good. Ideas? Solutions found?
Old Sep 9, 2016 | 12:47 PM
Chrispy0530's Avatar
Maybe a video with said rattle would help a bit. Kinda hard to diagnose noise issues with word descriptions.
Old Sep 9, 2016 | 05:30 PM
meckert's Avatar
The difference between you and I. Nope no video, I cant be the only one with the issue and the description is spot on--if you had the problem you would recognize the verbiage.
Thx, though.
Old Sep 9, 2016 | 09:53 PM
4b11slayer's Avatar
Clutch chatter
jonwtf416
Apr 15, 2015 09:35 PM
kstpeter33
Aug 16, 2009 03:34 PM
sgornicki
Feb 20, 2004 01:25 PM
alex_alex
17
Aug 13, 2003 05:49 AM
909
May 26, 2003 06:11 PM
