Need advice onOil pressure sender install
Old Sep 27, 2016 | 04:18 PM
Bman513's Avatar
I have a evo 9 and was wondering if I should get a sandwich adapter and if so which is the best? Or if there's a place on the block that i can just screw in the sender
Old Sep 27, 2016 | 04:27 PM
Pal215's Avatar
There is a plug on the oil filter housing that you can remove and place a 3/8 inch BSPT to 1/4 inch male JIC (-4 AN) in it's place with either yellow teflon or high temp thread sealer. The plug closer to the outside of the car (near the tire) will give you filtered oil. The one to the left of the oem oil pressure sensor will give you unfiltered oil. You can use the unfiltered oil supply for monitoring oil pressure.
-pal215
Old Sep 27, 2016 | 04:32 PM
Pal215's Avatar
Taken from Dave-Cee's thread:
Use number 2.
-pal215
Old Sep 27, 2016 | 05:09 PM
josh_evo9's Avatar
-pal215
If you tap into the filtered oil, would that affect the oil pressure readings? I have my oil pressure tapped into the filter housing, unsure which spot exactly. But my hot idle pressure is about 6-7 psi on an AEM digital gauge. It will hit 0 psi if I clutch in and the rpms quickly drop. Though the dummy light has never once came on. Wondering if I should switch spots.
Old Sep 28, 2016 | 01:47 PM
Pal215's Avatar
Both should read about the same in terms of oil pressure. FP uses the filtered oil side with their oil feed install kit to keep their JB turbo's happy.
-pal215
Old Sep 29, 2016 | 05:26 AM
CaptainSquirts's Avatar
I'm using #2 area on the picture and I get 18-20 psi when oil is fully warmed up.
Old Sep 29, 2016 | 06:54 AM
APEXR's Avatar
http://www.rallysportdirect.com/part...-block-adapter
Just another option that works.
Old Sep 29, 2016 | 03:39 PM
Pal215's Avatar
At idle correct ?
-pal215
Old Sep 30, 2016 | 06:06 AM
Correct. And actually its 16-20, around that range.
Old Oct 1, 2016 | 08:08 AM
Akorallygood's Avatar
I read to get that screw out you have to heat it up because of the lock tight
Old Oct 1, 2016 | 02:27 PM
I wasnt able to torch mine right with a propane torch due to the angle and how little or how large the flame would get. So I did it without it being torched and that sucker was stupid hard to get off. I'm surprised I didn't round the hex bolt, I was very very close to rounding it.
the1tonton
Jan 30, 2013 06:56 AM
Hendrixmx
Jun 19, 2010 08:17 AM
Mitchubishievo
Feb 8, 2008 05:17 AM
XK120
Jan 30, 2007 10:44 PM
CarFanatic
14
Feb 28, 2006 07:08 PM
