Weird bogging issue when hard shifting into 3rd?
#47
Yes i have a wideband. every time this has happened i make the rookie mistake of not looking at the wideband. this is my first turbo car i have owned. when i get this cable in will do some logs and try to replicate the problem and report back with what it shows.
#50
A friend of mine has the same issue. Car bogs between shifts. Thought it was tune related, although no matter what we tried to lean it out between shifts, it would still do it. I'll try to swap his cam angle sensor see if that fixes anything. If you figure it out, please let us know.
#51
Does his DV recirculate?
#52
Lol.
Hopefully fixed the problem tonight. Was putting my dual port bov back on and found just a little red flag. Prob not a huge deal :sarcasm: The worm clamp holding my maf to the intake pipe was completely loose. I was able to pull the filter & maf off the intake pipe by hand..
Also, i found a little tear in the hose that goes from the uicp to the bov. I'm not sure if it goes all the way through but def going to replace it. Anyone know where i can get that exact hose?
HOWEVER!!!
I still am wondering why it was happening several months ago (the original video). Theres no way the intake has been loose for that long. So that's why I'm not completely sure that was it. But it def wasn't helping.
Nonetheless the tactrix cable will be here tomorrow so hopefully tomorrow afternoon or within the next couple of days i can get some logs.
HOWEVER!!!
#57
Thank you for the update. Which springs and cams were you using before and what have you changed them to? Are you using FP Red turbo at the moment like your signature says?
05LancerRA
Dec 12, 2014 12:02 PM
dtuned
Jun 4, 2009 02:02 PM
detroit pistins
Nov 24, 2008 10:40 AM
NivenHuH
Nov 6, 2007 04:58 PM
