Help! Torque Specs ughhh
Old Dec 27, 2016 | 12:10 PM
eXtreme-Speed's Avatar
Hey guys,
Searched high and low for these specs, even through the manual.
Need the following torque specs any help would be great!
On the Transfer case: the tail section that the driveshaft slides into. The 4 12 mm bolts.
The Acd banjo bolt on the transfer case
And the 4 nuts and bolts that connect the middle of the drive shaft together.
Thanks guys!
Old Dec 27, 2016 | 12:43 PM
LetsGetThisDone's Avatar
Tight, snug, and tight..
Old Dec 27, 2016 | 02:34 PM
nor11384's Avatar
FCOTM Winner
lol exactly what this guy said...never used torque specs for these and never had a problem...just use common sense...
Old Dec 27, 2016 | 04:34 PM
Lol. That is how I currently have them. Just don't want my damn driveshaft to fall in half while driving down the road haha. But I will take your word for it.
Thanks guys!
Old Dec 27, 2016 | 04:35 PM
nor11384's Avatar
FCOTM Winner
put some umph into it and youll be all right man...get r done...
Old Dec 27, 2016 | 04:40 PM
Youre doing the right thing in getting the torque value
We've all done it & continue to torque by feel, but that time when you over do it & snap a bolt
Torquing to spec leaves out the guess work, especially on rotating assemblies (i.e. drive shaft)
Old Dec 27, 2016 | 05:29 PM
Yeah I hear you! 7 years owning my baby, feel like I have become more **** over the years haha.
Old Dec 27, 2016 | 05:53 PM
barneyb's Avatar
Center drive shaft bolts 24+-1 or 25+-4 ft lbs depending on the page I'm looking at.
Old Dec 27, 2016 | 06:12 PM
kaj's Avatar
kaj
If you can find someone with an FTP site, I can upload the service manual. I think the EcuFlash website has it avail for download, also.
Old Dec 27, 2016 | 06:20 PM
Old Dec 27, 2016 | 06:37 PM
hutch959's Avatar
i think those torque specs arent in the maual because there are no "rebuild" instructions in the manual.
so.... if i was you, around 25 n.m since your in aluminum threads.
Old Dec 27, 2016 | 07:04 PM
kaj's Avatar
kaj
Every torque spec for every part is listed in the shop manual. That's where the pics above are from. And where are you seeing aluminum threads?
Old Dec 28, 2016 | 09:02 AM
The tcase is all aluminum...lol
Old Dec 28, 2016 | 12:19 PM
kaj's Avatar
kaj
Ah. I didn't see that in the pic posted above and thought that's what he was replying to. LOL.
Then I scrolled back up and re-read this, "The Acd banjo bolt on the transfer case"
Old Dec 28, 2016 | 02:44 PM
barneyb's Avatar
FSM - Nothing for the tail piece either.
