Is it necessary to break in twin plate clutch?
Old Dec 29, 2016 | 09:53 PM
4b11slayer's Avatar
Originally Posted by eddy5201314
sorry?? So was that I used the wrong bearing that's why it's making so much noises? Pls help!! thanks
Im not sure. Ive never seen that clutch
Old Dec 29, 2016 | 11:18 PM
eddy5201314's Avatar
Originally Posted by 4b11slayer
Hmmmmm
okay thanks, can someone help pls.?
Old Dec 30, 2016 | 01:29 PM
LetsGetThisDone's Avatar
Only certain clutches convert from the OEM release bearing to a hydraulic. From looking up this clutch, it uses the OEM one..
I'm not sure what the noise is. Sounds like something rattling.
Old Dec 30, 2016 | 03:12 PM
yeah it's only rattling when I'm driving at low rpm 1500-2000 if I press in the clutch the rattle noise is gone. I'm worrying that noise isn't coming from the shop or the shop install it incorrectly?
Old Dec 30, 2016 | 03:26 PM
It's really hard to say without being there. I would take it back to the shop and see if they can help you out with it.
Old Dec 30, 2016 | 04:51 PM
what about the clutch pressure is just like stock? Is this normal? Aren't twin plate suppose to be heavier than stock ? Thanks
Old Dec 30, 2016 | 05:24 PM
That would depend on the clamping force of the pressure plate. The clutch you bought, the company advertises on being close to stock pedal feel..
Old Dec 30, 2016 | 05:35 PM
barneyb's Avatar
Over time the throw out arm, where the throw out bearing slides and the pressure plate all get filled with brake dust and become stiff. So, the pedal effort on a stock clutch increases but so slowly you don't feel the difference. A new stock clutch will feel light.
Old Dec 30, 2016 | 05:51 PM
4b11slayer's Avatar
I think you are expecting a stiff pedal and your fine.
I guess if it doesn't slip then your ok?
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
54
Jun 1, 2010 01:04 PM
Emperor666
Mar 24, 2007 08:33 AM
si_eater
22
Apr 11, 2005 07:39 PM
ez76
19
Sep 7, 2004 04:20 AM
PocketAces
Sep 29, 2003 12:04 PM
