What power can I make on a FP black
Old Mar 23, 2017 | 05:50 PM
djelliott978's Avatar
Looking to see what I can make on this setup
2.3L stroke w/built head S2 Cams
Skunk 2 intake mani w/ S90 Throttle body
3" Intercooler pippin to a ETS 4" Core
FP Race Manifold,
W/ Old Skoo FP Black BB w/ External 38mm
Tial wastegate,
ID 2000 injectors
Built 5 Speed w/ Excedy Twin DiSC
Walboro 455 high pressure fuel pump w/
-8an feed & Return Lines
Dual map E85 & Pump
Thanks for the help
Old Mar 23, 2017 | 06:13 PM
kaj's Avatar
kaj
Everyone is going to tell you the same thing: search
Old Mar 23, 2017 | 06:29 PM
tbaird58's Avatar
https://www.evolutionm.net/forums/ev...-pump-gas.html
this is similar to what you have and took me 10 secs to find...
Old Mar 24, 2017 | 06:13 AM
mavraolan's Avatar
I think,
500-530 whp on pump gas
600+ on E85
Old Mar 24, 2017 | 10:58 AM
kaj's Avatar
kaj
It's been done a million times. You can probably find a thread on this site for about any FP setup you can think of.
Old Mar 24, 2017 | 11:29 AM
Originally Posted by mavraolan
I think,
600+ on E85
thanks that's what I'm kinda hoping for
Old Mar 28, 2017 | 09:12 AM
silent_white's Avatar
why would you not use the GSC R2 cams?
Old Mar 28, 2017 | 09:46 AM
AWD96's Avatar
On STM's mustang dyno, with an HTZ Black (worth 30hp or so over the HTA) and a built 2.0LR I made 652whp/530wtq @44psi FWIW
Obviously different mods yield different results. My setup was fairly basic with Cossie M2's, NO porting whatsoever.
Most HTA Blacks on mustang dynos produce in the 575-600hp range
Old Mar 28, 2017 | 10:32 AM
kaj's Avatar
kaj
... and completely different turbos.
Old Mar 28, 2017 | 10:42 AM
AWD96's Avatar
Turbine is the same size, compressor dimensions are the same, just the Aero was improved. If i was talking Red/Green/Zephyr/Zero then it'd be a different story. My info was relevant
Old Mar 28, 2017 | 11:17 AM
kaj's Avatar
kaj
He has the old black, you have the HTZ which you admitted makes more power. How is he supposed to estimate his results based on that? Take your numbers and "subtract about 30whp but who really knows since it's a different turbo"? If we want to be picky, you didn't even have the same displacement. There's not really he can take from the information you provided.
You even make note of the difference in your own post:
Slow Evo
Mar 18, 2007 03:45 PM
Big Turkey
10
Feb 9, 2005 02:38 PM
Kaane
Jan 27, 2005 10:39 AM
evodave
25
Jan 12, 2005 06:32 PM
