Loud whine after changing rear diff bushings
Old Apr 21, 2017 | 08:19 PM
Evo47's Avatar
I bought the black energy suspension rear differential bushings and only changed the mount bushings and not the mustache bar ones (seems like a pain to do). Anyways the famous clunk is gone but now I got a noticeable whine which I can hear in most gears. It's quieter in 5th gear and louder in higher gears. What could it be?
Old Apr 22, 2017 | 07:05 AM
LetsGetThisDone's Avatar
Differential noise. A new ring and pinion gear with proper setup will make it go away.
Old Apr 22, 2017 | 09:37 AM
kaj's Avatar
kaj
Mine does the same thing. I took it to a local shop and they said it checks out fine.
I removed my interior at the same time, so that probably makes it seem even worse. Lol
Old Apr 23, 2017 | 10:17 AM
It's "normal" in the sense that gear setup from factory sucks in these cars. Whining went away for me with a gear set and correct setup of the contact pattern.
Old Apr 23, 2017 | 12:12 PM
nemsin's Avatar
I would send it in to be serviced and have the plates restacked correctly.
http://www.teamrip.com/EVOLUTION%20R...20SERVICE.html
http://sheptrans.com/product/evo-4-9...ntial-service/
Old Apr 23, 2017 | 02:12 PM
kaj's Avatar
kaj
I don't mind. My Mustang did the same thing. I don't even notice it any more.
Old Apr 23, 2017 | 10:05 PM
Evo47's Avatar
So technically nothing is wrong? I did hear a tiny whine just before I changed the bushings, but it wasn't anything that really distracted me, but it got noticeably louder as soon as I changed the bushings. Also changed the fluid with OEM diaqueen. Will the diff eventually fail on me or is it a normal whine? Also, my trunk had no carpets so that might be increasing the sound a little bit
Old Apr 24, 2017 | 01:05 AM
kaj's Avatar
kaj
stiffer bushings = less vibration dampening. You will definitely hear more. My car sounds like I have straight-cut gears, since the inside is basically a drum now LOL.
FWIW I have 130k miles on my rear differential. I swapped bushings out two years ago. If it dies, it dies and I'll have it rebuilt.
Old Apr 24, 2017 | 10:26 AM
barneyb's Avatar
The reason the factory bushings are soft and clunk is to isolate gear noise.
Old Apr 26, 2017 | 11:09 AM
Nothing is particularly "wrong". It will go a long ways making some noise. But the noise can be dealt with by replacing the gear set.
Old May 2, 2017 | 03:22 PM
reboundicon's Avatar
Yeah changing the bushings usually results in louder cabin noise and whine, this is completely normal on our cars.
AustEvo
May 4, 2018 03:02 PM
EVO(boss)
12
May 10, 2016 06:39 AM
deeman101
16
Dec 2, 2014 09:16 PM
ogarcEVO
Jan 28, 2014 10:29 AM
inco9nito99
Aug 28, 2009 02:00 PM
