Need New Alternator, Where to Buy?
Old Oct 14, 2017 | 11:09 AM
smoothevo's Avatar
Where are you guys buying alternators from? Just the cheap auto zone (link) or something else?
Old Oct 14, 2017 | 01:13 PM
Biggiesacks's Avatar
i think there are a bunch of people selling them over in the private classifieds thread. Dunno if any are brand new though.
Old Oct 14, 2017 | 02:36 PM
smoothevo's Avatar
Thanks but I'm more concerned with longevity than the price. I don't think they sell band new OEM units so I want the best/good remanufactured unit. I know it's a PIA so I don't want to do this again any time soon.
Old Oct 14, 2017 | 03:21 PM
barneyb's Avatar
If you don't like doing it again refrain from remanufactured units. They come with a lifetime warranty for a reason. The reason is they let you replace them until you hit upon a good one.
Old Oct 14, 2017 | 03:48 PM
smoothevo's Avatar
Yes I understand that but the problem is I don’t believe anyone makes brand new units for our car. I’m just trying to find people who have replaced theirs and where they purchased them.
Old Oct 14, 2017 | 03:58 PM
gsrboi80's Avatar
Replaced mine with a new aftermarket unit, I forgot where I bought it from was a little over a year ago
No issues to speak of!!
Old Oct 14, 2017 | 04:31 PM
http://streettunedmotorsports.com/parts/oem_mitsubishi_evo8_alternator.htm
Old Oct 14, 2017 | 04:36 PM
Chrispy0530's Avatar
This is the way to go if you don't want to touch your alternator for a long while. Seeing how much of a pain it is remove the alternator, OEM is the best choice imo.
Old Oct 14, 2017 | 05:18 PM
smoothevo's Avatar
Thank you. Wasn't aware they still made them.
Old Oct 15, 2017 | 10:57 AM
ExViTermini's Avatar
Replacing the alternator is really not that hard...
Anyway, I have an oreilly's one my car, has been doing well, and I've had good luck with their units in the past. The other parts chains I can't say I've had good luck with.
Old Oct 16, 2017 | 12:27 PM
Zedicus's Avatar
5 Year Member
alternators and A/C compressors are some of the few things i actually prefer a reman part on. its usually just the front case bearing or the regulator in an alternator that goes bad. really not worth the 300$ for a new one. heck i have been super cheap and spent the 20$ for the case bearing and 35$ for the regulator and put them in an old alternator myself. good to go for another 100k miles.
Old Oct 25, 2017 | 10:42 AM
BrownParticles's Avatar
I'd rather keep my core and let a rebuilder do his/her work over purchasing an aftermarket unit.
Old Oct 29, 2017 | 08:11 AM
smoothevo's Avatar
Bought a new one from STM and installed it. Getting that **** out was the hardest part. I had an alternator bracket that couldn't be removed. Nut holding it in place was under a pulley.
Just in case someone searches this:
- remove wheel
- remove belt using tensioner
- remove 2 nuts and 1 bolt from alternator
- unplug sensor from alternator
- remove nuts holding abs
- remove nuts from ps line
- remove nuts from ac line
- remove 2 bolts end of fuel rail remove that (brain fart can't remember what it's called)
- remove alternator bracket
- remove cam gear cover
- remove passenger motor mount bolt
- jack up passenger side of motor under oil pan using a piece of wood to displace the weight
- take out oil dip stick
- scrape up you knuckles cussing pulling and pushing things out of the way to get the alternator out
Thread that helped me https://www.evolutionm.net/forums/ev...nator-top.html. I had to remove/move some additional items.
Old Oct 29, 2017 | 08:48 PM
Much easier to just remove the axle right quick...Glad you got it done but def sounds like the hard way.
TempeRacerGuy
185
Apr 5, 2010 11:00 AM
bbyevo8u
Apr 27, 2009 06:02 AM
tabio42
40
Dec 30, 2008 12:04 PM
Boost3dxEvO
Nov 15, 2007 12:43 AM
LOTL
Lancer Engine Tech
Oct 21, 2004 01:30 PM
