Idle surge, lean reading (22) near 1k, map issue?
Old Sep 27, 2019 | 05:45 AM
Derekhollister's Avatar
I’m trying to figure this out my evo 8 is surging idle, reading lean. I’ve smoked the intake nothing was leaking, I’ve pressure checked intake system and couldn’t find a leak. When I had it running yesterday I pulled maf and the car would stall so that checked fine I did the same with the map and this time it didn’t change the way the car ran wether it was plugged in or not. Debating this is a issue. I have no codes.
Is is there a test to actually test the map sensor. It’s a oem one.
Old Sep 27, 2019 | 07:08 AM
DontStopMe's Avatar
Did you check your IAC?
https://www.evolutionm.net/forums/ev...lets-talk.html
Old Sep 27, 2019 | 07:51 AM
No because I don’t belive it’s the Iacv since my fuel trims read lean and the idle it surging, a iacv would just cause surging idle but no cause it to lean. This is either a vaccume leak as I stated I found none or possibly the map as it makes no different how the car runs with it plugged in or unplugged
Old Sep 27, 2019 | 08:26 AM
DontStopMe's Avatar
This was not the case with my evo.
If i was slowing down/ costing to a stop in neutral, my idle would surge and my AFR would go lean.
Its easy to check your IAC, i suggest still taking a look. It could probably use a cleaning either way.
Old Sep 27, 2019 | 09:35 AM
I can’t even drive it, it’s as soon as the car starts it will go up then surge, I mean I’ll check it so it’s something else I can check off my list.
Old Sep 28, 2019 | 12:15 PM
Think this may be my issue looks like my iacv is stuck
https://drive.google.com/file/d/1GVO...w?usp=drivesdk
Old Sep 30, 2019 | 06:25 PM
Is it possible to clean the valve and make it unstuck? Or is it only buy a replacement?
Old Oct 1, 2019 | 07:32 AM
DontStopMe's Avatar
Your google drive link doesn't really work. need "permission" to view.
You can try cleaning it with brake clean. Otherwise... save yourself the headache of dealing with it again in the future and just spend the $$$. https://www.maperformance.com/produc...caAqymEALw_wcB
Old Oct 1, 2019 | 09:13 AM
Darn it won’t upload the video on here, it buzzes but doesn’t actuate. I seen a list of other vehicles that share a iacv thought about going through junk yard. Would rather not spend a lot and it not be my issue if that makes sense. It isn’t actuating meaning it will cause a issue but idk if it’s the issue mine is having.
Old Oct 1, 2019 | 09:56 AM
DontStopMe's Avatar
I certainly understand. Did you read/view the thread I posted in my first post? I had a very similar reason for starting it.
I can't see your video, but i assume you pulled out the IAC and it looks okay visual, and not worn like the one show in my other thread? (https://www.evolutionm.net/forums/ev...lets-talk.html)
Old Oct 1, 2019 | 10:02 AM
Mine has the external spring, it’s covered in carbon. It isn’t fried just the plunger is stuck, hoping I’m able to clean it and get it free. I’ll prob take it off and soak the plunger to work it free and see if I’m able to save it
Old Oct 6, 2019 | 10:12 AM
Well cleaned it the valve moved. Started the car it idles about 1500 then after a bit it goes up a little. If anywhere near 1000 rpms it’s stupid lean and about stalls out. I got a code p0441 which I’ll have to look into
Old Oct 6, 2019 | 10:18 AM
https://drive.google.com/file/d/1Rp8...w?usp=drivesdk
Sheasta
Jan 30, 2016 10:48 PM
beasters
Mar 27, 2015 05:06 AM
hediki12
Jan 28, 2010 08:49 PM
nonschlont
Dec 10, 2009 08:32 PM
RaiNFaLL
Lancer Troubleshooting
Jan 10, 2009 02:19 PM
