Whirring noise!?!!
Old Jun 13, 2021 | 01:53 PM
Dm30213's Avatar
Whirring noise!?!!
Could use some serious help, I’ve had a whirring noise coming from the front end ever since changing out a few parts: MR Evo wheels + tires that came with them and fortune auto 500 coilovers. The whirring noise gets more audible as I accelerate, off throttle at higher speeds it’s also very audible. Neighborhood speeds I don’t hear anything. I’ve listened to t-case whines, but my sound is a lot more like metal on metal rubbing; best sound reference I can think of is a dust shield scraping noise (I don’t have any brake dust shields). Audio clip included below, hard to hear over test pipe but it’s a higher pitch whirring noise. Thanks in advance.
Things I’ve checked/replaced:
- passenger wheel bearing
- passenger axle
- t case fluid replaced to see if I had any bad metals in there (nothing)
- oem brake lines were initially hanging a little low, zip tied them higher
- alignment (x3)
- swapped tires/wheels with someone (noise still present)
- removed calipers and depressed each piston with ease + cleaned and greased the pins
File Type: mov
Old Jun 13, 2021 | 04:06 PM
hutch959's Avatar
have you got it on a lift and let it idle in 2nd or 3rd??
to see if you can locate the noise?
Old Jun 13, 2021 | 05:19 PM
Dm30213's Avatar
I haven’t let it idle in 2nd or 3rd but I ran it in 2nd gear on a lift. And I was told the sound was loudest on the passenger side wheel. So they concluded wheel bearing and there was also slight play. But after having changed the wheel bearing no luck.
AlexGutEvo8
May 24, 2015 11:35 PM
Jaxson75
Lancer Troubleshooting
Apr 11, 2015 06:59 AM
mister1161
Feb 7, 2015 12:38 PM
Betty
Apr 30, 2012 12:59 PM
eag36
Apr 17, 2007 05:29 AM
