New here / MAF issues
Old Jun 22, 2021 | 04:14 PM
noodletoots's Avatar
Question New here / MAF issues
Hello, I am very new here but have lurked for a while. I have an 03 Evo 8 I bought that is 80% stock on built internals. Long story short I am having issues that I cant rule out if its a tuning issue or not. Before I bought a new MAF the engine would die when it was plugged in, or use way way too much fuel when not plugged in, so I bought a new one. Now with the new one, when plugged in the car starts and idles fine but looses all boost under load, straight 0 on the boost gauge. But when unplugged the car just dumps gas in and smokes really bad. I am at a dead end and need some guidance. Shop did a boost leak test and there are no leaks. Also did a compression test for a different issue that has been worked out and have good compression across every cylinder. I live in Nebraska and there aren't any tuners that I know of in Omaha, was recommended someone in Sioux Falls but cant get the car there. Hoping its not a tuning issue but wouldn't rule it out.
Old Jun 23, 2021 | 05:01 AM
Biggiesacks's Avatar
Is it throwing any trouble codes?
Old Jun 24, 2021 | 03:40 PM
No, no trouble codes, tried to run it around a little in hopes that it would throw one.
Old Jun 24, 2021 | 03:59 PM
You need to run an ECU log on it & that should show what is going on.
Old Jun 25, 2021 | 12:42 PM
Ok. Has anyone used Evoscan around here before? I was thinking about getting Evoscan and ECUflash just to peep around but I don't want to catastrophically **** up the car.
Old Jun 25, 2021 | 02:19 PM
Evo9_Dubai's Avatar
No I doubt anyone has ever used Evoscan here before. I might even go as far as saying many don't even know what evoscan is.
Jokes aside, you won't **** anything up by simply logging. If you intend to read/write to the ecu, just backup the original rom.
Old Jun 25, 2021 | 03:21 PM
Lol, thanks for the info. I have to get an adapter still so there will be a break between responses. Other than that, any recommended OBD2 connecters other than the one on the ECUflash site?
Old Jun 29, 2021 | 03:57 PM
iD33's Avatar
I had a similar issue with my MAF, would hesitate for a split second at 3K RPMs. Replaced with another MAF and bad my tuner adjust the tune. For now pull the log from Evoscan or ECUflash.
Old Jul 19, 2021 | 04:09 PM
Question
Hello again, after the long wait my scan tool is here, and let me start by saying there is alot to look at on EvoScan. If I were to want to find my MAF to see what is going on with it, where would I do so? On top of that, what would I need to change once I get there? Any hint is helpful, and I I will be out of town from the 21st to the 25th. Thank you all.
Old Jul 19, 2021 | 05:24 PM
Edit: Went out and played around with EvoScan and learned what to do to log it, im having trouble connecting to the car currently, and when i started the car, it was chugging worse than before.
Old Aug 17, 2021 | 11:15 AM
Question Need Help Reading Logs
A lot of info here, I did 3 logs, 1 at idle, 2 is with a little throttle, 3 is a round the cul-de-sac in 1st gear. Please **** on me all you want as long as there is some advice in there somewhere. I did these all with the MAF unplugged and forgot to get one with it plugged in. Please help, I just want to enjoy this car for once instead of having a headache.
File Type: csv
File Type: csv
Old Aug 17, 2021 | 11:34 AM
MAF logs
Here are the logs with the MAF plugged in.
File Type: csv
@_damianhyde
Apr 5, 2021 04:27 PM
kevinevo4
Feb 20, 2021 04:56 PM
envdevo9
May 5, 2013 12:28 PM
5LEEPERISAH23I
Feb 26, 2011 01:06 PM
booster9
North Texas Evo Club (NTEC)
May 13, 2009 11:31 PM
