Gas Tank
Old Feb 13, 2023 | 03:55 PM
benIX's Avatar
Gas Tank
what's up evo fam,
I have a little issue. my fuel tank I broke the studs to the fuel pump ring. I only have 3 studs left.
I know there are couple of threads there that talks bout replacing and one actually repair it with welding the studs somewhere else.
is there any other way of fixing this? specially since you cant get a new fuel tank anymore.
all the help is appreciated it. admin please remove if not allowed.
Thanks
Old Feb 13, 2023 | 04:32 PM
LetsGetThisDone's Avatar
The couple threads you found are what you're going to need to do. Or find a good used tank.
If you're not capable of welding, find a competent shop to handle it.
Old Feb 13, 2023 | 11:33 PM
ViciousLSD's Avatar
you could probably put a rivnut there
Old Feb 14, 2023 | 08:51 AM
benIX's Avatar
you mean drill and put the rivnut on the tank?
will that no leak?
i was thinking to drill the studs tap and put a new stud in there with red loctite. Not sure if that’s a good idea or not.
thanks
Old Feb 14, 2023 | 09:11 AM
ViciousLSD's Avatar
will that no leak?
thanks
I dont remember what kind of material is there. if theres enough material to tap then go for it. the rivnut is also threaded you can put a stud in and seal. if not possible, maybe just apply apply pressure on the flange somehow.
Old Feb 19, 2023 | 06:12 AM
michael_cano's Avatar
I broke mine too, I’m adding rivnuts to hopefully solve the problem. I’ll update how it goes
Old Feb 20, 2023 | 07:44 PM
Got it buttoned up today, added rivnuts all the way around the lock ring and it sealed up nicely. Hopefully it stays that way haha.
Bignel00
Jun 8, 2017 04:42 PM
5k6
Mar 5, 2017 07:25 AM
Masterr
Dec 13, 2016 04:52 PM
PhantomBlackEVOX
For Sale - Part Outs
Aug 2, 2013 09:39 PM
